Results 1 to 4 of 4
Thread: Idle is crazy
    I've got you, Pepe Le Bitch... Regular Member slvrGT179's Avatar
    Apr 2010
    College Station/Austin/Spring
    Idle is crazy
    I've been having issues with my idle. It goes from 1000-500 in a straight shot. That's without a/c on. Can anybody tell me what might be causing this? And I've also been having issues withy clutch and flywheel if that's any factor in this.
    K&N CAI, SCT 91 tune, PI intake, Pypes O/R x-pipe, Flowmaster 40s,
    FRPP 3.73s, RAM clutch kit, adjustable clutch cable, rebuilt T45,
    Pro 5.0 short shifter, KYB AGX adjustable shocks/struts,
    Eibach lowering springs, Maximum Motorsports CC plates,
    Hyperblack Saleens 18x9 w/ 275s & 18x10 w/ 285s
    MOAR LEETERS Weilding the ban-stick proudly JCP281's Avatar
    Jun 2007
    San Antonio
    is your tb/plenum aftermarket or stock?
    Either you have a vacuum leak, your IAC valve is dead or your throttle stop screw is not within spec position.
    Get a feeler gauge and set your throttle stop screw up if your tb/plenum was newly added.
    Heres the tutorial:
    PaladinMicro
    Quote Originally Posted by Steve View Post
    Nah it just looks good when people are behind it in their ancient pushrod tech equipped trailer trash mobiles.
    Apr 2010
    I have a stock tb/plenum. How would I be able to check for a vacuum leak?
    Jun 2007
    San Antonio
    Get some soapy water and spray it on all the PCV tubes IAC tubes and all the other places air is drawn through. if bubbles form around a spray spot patch up the hole.
