Idle problem?
When I started up my car today I noticed it was idling rough, and my rpm dial was below 1. What could be the problem it was running fine the last time i drove it which was Wednesday. Thanks in advance.
LOL @ your mom
IAC's are known for failure on these engines... try removing it and cleaning it with carb cleaner, do the MAF as well just to keep the sensor wire clean.
LOL @ your mom
Rather then type out how to do it, just click HERE instead.
Decent write up there.
LOL @ your mom
Should be.. they normally act up on first starts and cold mornings.
LOL @ your mom
Carbon build up is 80% of the cause usually, but it is also an electrical issue at times as well. You can clean it once every 15k miles for added insurance it stays clean, but when it fails electrically, there is nothing you can do. Somewhere I have a good used one, I'll have to dig it up, but it is a OEM IAC.
LoneStarStangs Addict
what happened with this, I have this problem, and am down to the last thing I need to check, just havent had the time
![]() IN LAK'ECH YUCATEC MAYAN CODE OF HONOR "I AM ANOTHER YOURSELF" Impossible Maze Game<<< Really a maze game, not the song anymore |
It's LOUD but YOU looked!
you should only clean the IAC as last attempt. this is not a clean regular thing. we tend to have a lot of hot weather in SA. so when the cold hits the IAC has to "unscrew" more than normal. which gives that temp run rough. most of the time it will fix itself. this is just like car batteries in the cold as well...
Deep thought... Why do they call it an asteroid when it's outside the hemisphere, but call it a hemorrhoid when it's in your butt?
I cleaned the IAC and replaced the PCV valve, now I am going to try to change the electronic part, cant remember what its called, but it has a sensor and two screws. It is attached to the Plenum if I remember correctly.
LOL @ your mom
TP sensor.
THATS IT! Couldnt remember, you wouldnt happen to know what it should read when I test it with the voltometer do you?
#16 |
LOL @ your mom
With it on at idle, about .90 volts and to WOT 4.5-5V
#17 |
So if its anything other than that, I should replace it? And I didnt even know you tested it while it was on the car, I figured you had to pull it off. To test it I just remove the plug and test the inside of the tp sensor?
#18 |
LOL @ your mom
No, you back probe the wires. It needs to be plugged in due to the V-REF for voltage. You can ohm it, but I do not rely on ohms, voltage is a better way to test.
#19 |
LOL @ your mom
Schematic ...
#20 |
ok... the schematic was supposed to show me how to do what?
