Old 07-12-2008, 03:59 PM   #1
INJECTOR QUESTION
will 24lbers from an 05-07gt work on a 01gt....thanks
greenhornet347 is offline   Reply With Quote
Old 07-13-2008, 10:26 PM   #2
Dumb and dumber
Trader Rating: (17)
No, you need the adapter harnesses to be EV6 to EV1.
Or just pig tails from an EV6 cut and spliced in.
Originally Posted by hoss302
