Old 07-10-2007, 04:17 PM   #1
Nice Hat SUfanINsa (Steve)
Agent Jones's Avatar
Install Instructions
Anyone know where i can get a walk through or something for installing a x-pipe and MILs on a 07 Gt??? I bought the pipe 2 weeks ago and local shops are estimating $100+ for install, so i wanna try and do it myself.
OU > UT > TT
Agent Jones is online now   Reply With Quote
Old 07-10-2007, 07:32 PM   #2
tapitty tap tap
bucho's Avatar
Send a message via Yahoo to bucho
they may have something on here for ya...good luck!
Mustangworld How-To's INDEX
bucho is offline   Reply With Quote
Old 07-26-2007, 03:51 PM   #3
aka...BlackJack
Machine's Avatar
Send a message via AIM to Machine Send a message via Yahoo to Machine
it's been over a year since i changedd mine, but here's a real quick summary for ya...
loosen your mufflers at the connector sleeves
remove the 2 nuts on each flange coming off the headers
loosen the sleeves that connect the mid pipes
slide the stock H out and replace
put it all back together in reverse...
before you tighten things back up, make sure your mufflers are nice and centered...
SCT, JLT, Pullies, Gears, 3000 stall, BMR LCA's, Steeda Superlites, O/R H, Mac Axlebacks and BAMACHIPS tuned!
Machine is offline   Reply With Quote
Old 07-27-2007, 10:34 AM   #4
mils and xpipe are a 70 dollar install at psi . 1 hour labor unless you have the mills wich require cutting and reconecting the 02 wires in wich case ad another half hour.
and definatly something that can be done by you if you have simple hand tools
PSI
Performance Solutions
210-655-6546
10811 nacogdoches road
San Antonio TX 78217
cmr tuners and full service
performance shop.
Old 07-27-2007, 10:54 AM   #5
On with the show....
Cruehead's Avatar
Yeah...real easy. It can be done in under an hour on jackstands. Basically, 2 bolts to both headers, 2 bolts to each over-axle connection, and 3 O2 sensors to remove and replace. I remember someone doing a write up on it...I'll try to find it.
Dave
'07 Redfire GT
Flowmasters, Pypes H Pipe w/ Hi-Flow Cats, C&L CAI, SCT X-Cal2 (BamaChips), FRPP 4.10's
Cruehead is offline   Reply With Quote
Old 08-04-2007, 10:46 AM   #6
aka...BlackJack
Machine's Avatar
woops, thats right...forgot about the O2's...you'll need and extension and possibly an elbow to get at that top one...
Old 08-04-2007, 01:32 PM   #7
keg65's Avatar
unplug harness
wait to remove the O2's until after the H pipe is off, and put them on the X pipe before install
1 of 472
