Old 10-25-2004, 09:52 AM   #1
VIC
The "Senior" Member
VIC's Avatar
Send a message via AIM to VIC
Installing new front brake pads
My front brake pads are about due to be changed. (97 V6)
I forgot what size "torx bit" is needed to remove the caliper. I "think" it is a size 50 which I don't have so will have to buy one. Is 50 the correct size??
Thanks....
Old 10-25-2004, 09:52 PM   #2
Thanks....
Its eathier a T50 or a T60 which a lot of caliper bolts are. A little trick I learned from another mechanic, if you dont have the right size torx you can use an allen wrench that fits snugly in the hole and it wont strip the star out. Done it many times and it works.
Old 11-02-2004, 02:01 PM   #3
tire's Avatar
same as what he said... not sure on the torx size but allen wrenches CAN work fine with some WD-40 and a firm hand.
