Old 12-05-2007, 10:06 AM   #1
I'm back! FT.Eutis, VA
Ryan_65Stallion's Avatar
Installing tachometer
I picked up an tachometer for my car about a month ago and have yet to install it. I'm waiting til my dad helps me install this GM Style HEI distributor moddified for ford 289/302.
I was wondering if anyone here has installed on and where I could run the wires throught the firewall, and also where I could locate a wire that would turn the light on when I turn the lights on like at night.
Soon to be at Fort Lewis, WA.
1-60th NightStalkers, Special Operations Aviation Regiment, SOAR. 15U, I'm a hooker! MH-47E Chinook
Army Aviation Leads the Way!
1965 Mustang 289 V8, under constuction
Holley 4brl 650cfm carb
Edlebrock Performer Intake
and soon to have Comp Cams Nostalgia Plus, N+271H camshaft
Old 12-05-2007, 10:40 AM   #2
The light wire you need to find is the one that comes off the Headlight switch and sends power to your dash lights. Simple matter of using a test light to find the correct lead.
As for passing the wires thru the firewall you should be able to find a hole in the firewall if not drill one but use a rubber grommet to avoid chaffing the wires no matter what hole you use
Old 02-18-2008, 10:17 AM   #3
Send a message via AIM to pete68stang Send a message via MSN to pete68stang Send a message via Yahoo to pete68stang
Yea run it from ur indicator lights, do not run it from ur dash, it will short out over time, and run the other cable to ur negative side of the coil, and presto,if u have an msd box their is a output for tach. Works great on all my cars
*Imagination is more important than knowledge.......dare to dream*.....-Einstein
pete68stang is offline   Reply With Quote
Old 02-18-2008, 11:45 PM   #4
che pete dando tech advice Miralo!
1992 RED GT - 351w - 11.3:1 CR, AFR 185 heads w/ Frpp 1.6 Roller Rokers, Ed Curtis Cam & Linked Roller Lifters, Trick Flow 351R Intake, 30# Injectors, 75mm TB & SP, 90mm MAF, 3.73, T5, 1-3/4 BBK, 2.5" BBK H Pipe, Dynomax Race Bullets, 2.5 MAC Tailpipes, ASP Pullies, 190 lph pump, AFM Power Pipe
FAKE SNAKE is offline   Reply With Quote
Old 02-18-2008, 11:59 PM   #5
who brought this back from the dead?
I already got it installed awhile back
