Results 1 to 24 of 24
Thread: Installing underdrive pullies
    Apr 2007
    Waco, TX
    Question Installing underdrive pullies
    Wasn't sure where to put this, but hopefully it's ok here. Anyways, I'm thinking I'm going to try and install the pullies I've had sitting here for a while. They are believed to be Steeda's and are the good kind, not piggyback. I have a cheap battery powered impact that I can hopefully use for the alternator pulley and the water pump pulley shouldn't be a huge issue.
    The crank pulley/balancer however is where I may run into issues. Those who have done this before, were you able to remove the stock balancer with or without the remover tool? And also on reinstallation of the new balancer, did you follow proper torque procedures, or just snug it down real tight. I've watched the video in the link below several times, but I don't have a torque wrench so wasn't sure if I should risk it or not.
    Steeda 4.6L Underdrive Pulleys (Mid 2001-2004 GT) at AmericanMuscle.com - Free Shipping!
    LoneStarStangs Addict Regular Member 3.9LMustang's Avatar
    Jan 2009
    Corpus Christi
    if im not mistaken. you done have to take out the balancer. Only the bolts on the crank pulley.
    1995 Cammed/Turboed V6 Mustang (auto)
    13.3@103mph
    Built by Iron Horse Motorsports
    Apr 2007
    Waco, TX
    Quote Originally Posted by 3.9LMustang View Post
    Watch the vid, these aren't piggyback, the balancer gets replaced.
    Jan 2009
    Corpus Christi
    ahh ok just saw it :p
    13.3@103mph
    LoneStarStangs Addict Regular Member Dark04GT's Avatar
    Feb 2010
    NC
    The torque specifications, while not necessary, probably will give you the best results because the crank pulley doesn't go on that smooth. If you torque it down like the video, it does go on decently and it goes on even. I torqued mine similar to the video and I haven't had any problems for over a year. Torque wrenches are 70 bucks, it will be worth it in the long run.
    As far as getting a pulley puller I would say it is essential. You can't pull the crank pulley off, it is impossible in mustangs that are as old as ours. I broke a flat head screwdriver trying to get that thing out. Just break down and get a pulley puller (make sure you get the right kind, take a picture of the stock pulley if you have to). I went to autozone and I rented a tool and turned it back in later (you pay then get a refund.... it was actually free to rent). The tool made it way easier.
    Cliff notes: Get a pulley puller from autozone, get a torque wrench.
    DSG 04 Mustang GT
    Performance: C&L CAI, Accufab 70mm TB+Plenum, 24# injectors, Hitech stage 2 cams, MAC LT's, Prochamber, SLP hi-flow cats, Borla Stingers, Steeda UDP, SCT tune, Braille Battery
    Drivetrain: Tri-ax, FRPP Alum d/s, Exedy Mach 400 clutch, Fidanza Alum Flywheel
    Suspension: C-springs, MM CC plates, Tokico blacks, Eibach sways, X2, Steeda bumpsteer, FLSFCs, kyb quads, 17x9's w/ Nitto NT555 275's, Cobra front brakes, Hawk pads & Powerslot rotors
    Mustang dyno: 290rwhp/284rwtq
    A big thanks to Chris@STP for his work on my car
  6. #6
    Apr 2007
    Waco, TX
    Quote Originally Posted by Dark04GT View Post
    Which puller did you get? The one with the jaws or is it one that screws in. The underdrive one I have has threaded holes in it for removal, not sure if the stock one does or not.
    Yeah, I know about the rental tool thing so I was probably gonna do that. I know I've been needing a torque wrench of my own for a while, just never got it and don't really have the cash right now so might borrow one if I can. I wanted to do it today since it was such a great day, but didn't want to run into tool issues so thought I'd do some more research first.
  7. #7
    Feb 2010
    NC
    Quote Originally Posted by Bigdrumma22 View Post
    I seem to remember it was the one that screws in. Not 100% but pretty sure. I think both came with the rental kit I got so I had both just in case.
    DSG 04 Mustang GT
  8. #8
    Apr 2007
    Waco, TX
    Cool, so how much difference did you notice? Notice acceleration difference, or any slight mpg difference?
  9. #9
    drewskie68 Regular Member drewskie68's Avatar
    Apr 2006
    San Antonio, Tx
    Greg(mustangmelish) and i attempted this a looong while back on his 6er, and we used the one that screws in.
    C&L Cold air, Functional Ram Air Hood, Hurst Short Throw, MAC Offroad Prochamber, Stainless Works Axle Back.
  10. #10
    Apr 2007
    Waco, TX
    Quote Originally Posted by drewskie68 View Post
    When are you off, so you can help me fool?!?
  11. #11
    Apr 2006
    San Antonio, Tx
    hahaha i would like to add that WE didn't get it on, his dad helped him a day or so later... im down to help but wont have a free day till next saturday(13th)
  12. #12
    Feb 2010
    NC
    By the seat of pants dyno it made a noticeable difference. I remember being pretty happy with the mod.
    MPG wise maybe a 1 mpg bump at best. I still average mid-low 20's with mainly highway driving so I can't complain. I did average 27-29 mpg (each stop: 12.x gallons- odometer went to 350 ) on a cross country ~1200 mile trip on cruise control.
    DSG 04 Mustang GT
  13. #13
    Apr 2007
    Waco, TX
    Well, we will succeed for sure now that i've done more research. Just having an extra set of hands is great in itself sometimes.
    Cool, I think i'm gonna go for it for sure then. I've been kinda undecided up to this point.
  14. #14
    Apr 2007
    Waco, TX
    Anyone else have any useful input? May attempt it this saturday either on my own, or maybe at Don and Traci's if they're still available.
  15. #15
    "THINK WITH YOUR DIPSTICK JIMMY!" Regular Member jstang6969's Avatar
    Sep 2006
    Hamilton, Tx
    Yea, do a write up *with pics* for those of us that are to skeered to do it. lol
    Quote Originally Posted by 12second5.0 View Post
    I think he's busy picketing in front of the US mint telling them to remove " in God we trust" off of all currency............
  16. #16
    Apr 2007
    Waco, TX
    Quote Originally Posted by jstang6969 View Post
    Just watch the vid in the first link! Well if I do work on it at their place, maybe Traci will take some pics... haha.
  17. #17
    Newbie fresh fish!
    Mar 2010
    pm sent. i have the puller and all needed tools. just did a set on a stang today at work. let me know when and where
  18. #18
    Newbie fresh fish!
    Mar 2010
    if u dont want my help the water pump pulley bolts are 10mm and the crank bolt is an 18mm and i think the alternator nut is a 21mm. i just did a set today. im for sure on the h2o bolt size and crank but i cant remember the socket i used on the alt nut but pretty sure on the 21 mm. and if you wanna just borrow my puller and your promise to bring it back let me know and ill lend it to you. its the T shaped sorta one and the three bolts are 5/16 by 18 thread that go into the balancer. just let me know. ill be on and off the computer till later tonight.
  19. #19
    Apr 2007
    Waco, TX
    Quote Originally Posted by 2xblackcoupe91 View Post
    if u dont want my help the water pump pulley bolts are 10mm and the crank bolt is an 18mm and i think the alternator nut is a 21mm. i just did a set today. im for sure on the h2o bolt size and crank but i cant remember the socket i used on the alt bolt but pretty sure on the 21 mm. and if you wanna just borrow my puller and your promise to bring it back let me know and ill lend it to you. its the T shaped sorta one and the three bolts are 5/16 by 18 thread that go into the balancer. just let me know. ill be on and off the computer till later tonight.
    Thanks for the tips.
  20. #20
    Newbie fresh fish!
    Mar 2010
    anytime
  21. #21
    Apr 2007
    Waco, TX
    Got these installed earlier today, and can't say I notice a difference yet, but I'll give it a few more days and check my mileage the next few tanks to see if I see a change.
    Big thanks to Don and Traci for helping out with this project, along with my radiator fan issue. Got both taken care of today with their great help and awesome company.
  22. #22
    This is my Baaaaaby! What is SilverStar you ask?  Click here to find out! Mustang_68_Coup's Avatar
    Sep 2005
    San Antonio, TX
    ...maybe Traci will take some pics...
    Ooops. Sorry, I was busy digging in the flower beds ...
    Glad you came by! Its always nice to see ya!
    1996 GT Vert
    1968 "Vanilla" Coupe
    - Emo Phillips
    Quote Originally Posted by TheSource
    Young girls are hot as shit but usually stupid as a mother fucker.
  23. #23
    Apr 2007
    Waco, TX
    So just a lil' update, I'm hoping it's not a serious issue but I have noticed while sitting at long lights, that my voltage does drop down and the dash lights dim. But if I give it gas at idle or take off it charges normally.
  24. #24
    Dec 2003
    SanAntonio
    Normal deal with under drives. You are slowing the ALT down so it reduces its output especially at low RPM's. You can install a higher output ALT to reduce the issue if it bothers you. As long as your battery is good it really is no big deal.
    85GT FACH1 FINISHED
