Leaving July 3rd for the Army
If I buy a 4brl carb will I need to buy a 4brl intake manifold or just change out the carb spacer?
to my knowlege, they dont make a 4bbl carb to 2bbl manifold adapter... if they do it doesn't seem like it would be worth it... you can pick up a used air gap for fairly cheap, just do both..
It's LOUD but YOU looked!
you can bolt the carb on a 2b manifold, I did.
Deep thought... Why do they call it an asteroid when it's outside the hemisphere, but call it a hemorrhoid when it's in your butt?
Waste of time and money to do but they do sell an adapter for it.
Just go with a 4 bbl intake hell a stock cast 289 4bbl intake can be found for next to noyhiong and with yur car it would be a good way to get it done on the cheap and dirty.
Box Foxes Rule!!!
I sold a 289 4 bbl factory intake for 30.00
a few months ago. Dont waste time with the adapter,just find a 4bbl intake and do it right.
Ol' Skooler
I had somebody ask me this at work a few weeks back. Sure it's possible, but if you cheap out on this, you won't really get the benefit of a 4bbl. IIRC for what you're going for, see if you can eBay a Performer RPM intake, I imagine they'd be reasonably cheap. I have a Performer 289 and it's one hell of a torquemaker but runs out of steam much past 4k (though my cam probably has a lot to do with that too).
'67 Droptop - 4 show winner
620 front coils * 4.5 leaf mid-eyes * 1" front sway bar * KYB Gas-A-Just shocks * 14" Styled Steel Wheels * Dark Moss Green exterior * Ivy Gold interior * 302 bored .030 over * stock cam * stock heads * Edelbrock Performer 289 intake * Carter AFB 540 * Hooker long tubes * 2" H-pipe duals * 23" Cherry Bombs * C4 trans * 8" rear end/3.00:1 160.3hp @ 4300 --- 229.5ft-lbs @ 3100 before fan clutch! |
Agreed, as I said, I did it but then went with the edelbrock rpm performer intake. HUGE difference.
