Old 04-27-2008, 07:57 PM   #1
MR.SUPER TECH
Ryan_65Stallion's Avatar
Question Intake manifold question...
If I buy a 4brl carb will I need to buy a 4brl intake manifold or just change out the carb spacer?
1965 Mustang, 2V 289 V8, C4 automatic 3 spd
Mods: Edelbrock Performer 289 intake manifold, Holley 4brl 600cfm carb, Grab-A-Trak 560lb 1'' drop springs, MBMotoring 15'' wheels, 14'' K&N Extreme Air Filter Assembley, all aluminum radiator
My Streetfire.Net MyMustangSite My Myspace!
Old 04-27-2008, 08:25 PM   #2
to my knowlege, they dont make a 4bbl carb to 2bbl manifold adapter... if they do it doesn't seem like it would be worth it... you can pick up a used air gap for fairly cheap, just do both..
thatdavidkid is online now   Reply With Quote
Old 04-27-2008, 11:33 PM   #3
It's LOUD but YOU looked!
stangfreak's Avatar
you can bolt the carb on a 2b manifold, I did.
Deep thought...
Old 04-28-2008, 07:03 AM   #4
Waste of time and money to do but they do sell an adapter for it.
Just go with a 4 bbl intake hell a stock cast 289 4bbl intake can be found for next to noyhiong and with yur car it would be a good way to get it done on the cheap and dirty.
Old 04-28-2008, 09:21 AM   #5
Box Foxes Rule!!!
racer99's Avatar
I sold a 289 4 bbl factory intake for 30.00
a few months ago.
Dont waste time with the adapter,just
find a 4bbl intake and do it right.
of stupidity!
82 Granada Wagon,306/C4/brake/4.30s=fun!
Old 04-30-2008, 10:14 PM   #6
Ol' Skooler
I had somebody ask me this at work a few weeks back. Sure it's possible, but if you cheap out on this, you won't really get the benefit of a 4bbl. IIRC for what you're going for, see if you can eBay a Performer RPM intake, I imagine they'd be reasonably cheap. I have a Performer 289 and it's one hell of a torquemaker but runs out of steam much past 4k (though my cam probably has a lot to do with that too).
'67 Droptop - 4 show winner
620 front coils * 4.5 leaf mid-eyes * 1" front sway bar * KYB Gas-A-Just shocks * 14" Styled Steel Wheels * Dark Moss Green exterior * Ivy Gold interior * 302 bored .030 over * stock cam * stock heads * Edelbrock Performer 289 intake * Carter AFB 540 * Hooker long tubes * 2" H-pipe duals * 23" Cherry Bombs * C4 trans * 8" rear end/3.00:1
160.3hp @ 4300 --- 229.5ft-lbs @ 3100 before fan clutch!
jcp123 is offline   Reply With Quote
Old 05-04-2008, 11:34 PM   #7
stangfreak's Avatar
Agreed, as I said, I did it but then went with the edelbrock rpm performer intake. HUGE difference.
Deep thought...
