MY GF SAIDS I'M BORING
Just put on my control arms...
upper and lower MAC ones....it was a bitch putting them on...anyway, i hope it was worth the 4 hrs i spend putting them on...i'm hoping to knock off at least .1 off my 60 ft....
03 ZINC YELLOW MACH 1 RIP MODS: 4.10's K&N Aircharger MAC UCA's & LCA's MAC O/R X Spintech Mufflers Superchips Microtuner Yeah it's automatic ![]() NEW RIDE 2004 TORRID RED GTO MODS: XPIPE DYNOMAX BULLETS HSW 150 SHOT NITTO DRAGS FAST INTAKE TUNE CAM AND NO, IT'S A 6-SPEED
what kind did you get, are they solid or can you adjust those uppers? you can't use poly on both side bushings-wise or else it'll bind on you if you're going straightline. i'm trying to figure out what bushings i should have for my LCA's still.
How hard are the UCA's? I want to upgrade mine since I already have the LCA's....
2003 Redfire Roush Stage II #6395 377.5hp/ 372.9tq@ 8psi Small vid of blower ![]() <----Click for mods....
Ooh-Rah Marine Corps
It ain't always quite that easy. Mine took quite a bit of coaxing to line up the bolt holes. Course they weren't stock length either, so I'm sure that made it a bit more difficult. Getting the old bushings out was probably the biggest pain though. We swiss cheesed em with a drill, then put an air chisel on them. That worked pretty well.
![]() 88 vert Be polite and professional, but have a plan to kill everyone you meet. |
I may be doing mine this weekend. Is there any tips or words of good advise that might make it a little easier? Is there anything that I need to expect?
![]() 1988 Mustang LX |
#7 | |
lawrence, as for the uppers, piece of cake...
Did you replace the bushings in the upper axle? I got new ones to put in there and I heard they were a bitch. Other than that I see the rest of it going really smooth (hopefully).
Nope..the Mac ones i got came with bushings and all....the lca's were the hard part..
#10 | |
#11 | |
#12 | |
I replaced the bushings on top of the diff. The thing that sucked was you had to reuse the metal sleeve. We drilled them out with a drill, then hit it with an air chisel and that worked pretty good. A flaming hacksaw is supposed to make it pretty easy.
