Old 06-13-2008, 07:11 PM   #1
Kicker KX300.2 AMP
Kicker KX300.2 amp, works perfect and is very clean
Asking $100 and I am in the NW San Antonio area
If Interested either pm me here or email me at RLara85@gmail.com
This is the info from the manufacturer:
Manufacturer's product description
This amp is designed from the ground up to produce the tight, clean power you need to make your system roar. And you're in command with adjustable frequency/function active crossovers and variable bass boost built right in. The amp puts the power at your fingertips with remote bass control. Fast-acting protection circuits guard against bonking from short circuit, over-voltage, overheating, or wiring mistakes. You can even run this super-flexible amp in stereo and mono at the same time.
Audio system
Response Bandwidth: 20 - 20000 Hz
Signal-To-Noise Ratio: 95 dB
Max Output Power / Channel Qty: 110 Watts x 2
Continuous Power / Channel Qty: 75 Watts x 2
Input Channel Qty: 2 channel(s)
Amplifier Output: 2-channel
Output Channel Qty: 2 channel(s)
High Level Inputs: Yes
Input Signal Voltage: 0.34 - 10V, 0.17 - 5V
Crossover: 2-way active crossover
Crossover Slope: 12 dB/octave
Low Pass Frequencies: 50 - 200 Hz
High Pass Frequencies: 50 - 200 Hz
Bass Boost Frequency: 40 Hz
Bass Boost Gain: 0 to +18dB
Amplifier Output Details:
* 75 Watt - 4 Ohm - THD 0.085% - 13.8V DC - 2 channel(s)
* 150 Watt - 2 Ohm - THD 0.2% - 13.8V DC - 2 channel(s)
* 300 Watt - 4 Ohm - THD 0.4% - 13.8V DC - 1 channel(s)
* 110 Watt - 4 Ohm - 14.4V DC - 2 channel(s)
* 175 Watt - 2 Ohm - 14.4V DC - 2 channel(s)
* 350 Watt - 4 Ohm - 14.4V DC - 1 channel(s)
Additional Features: Input level controls, gold plated connectors, thermal protection, overload protection, bass level remote control, short circuit protection, reverse polarity protection
Connections
Connector Type:
* 1 x audio line-in ( RCA phono x 2 )
* 1 x audio line-out ( RCA phono x 2 )
* Speakers input
* Speakers output ( screw-type )
* DC power input ( screw-type )
RLara85 is offline   Reply With Quote
