Ok I’m back with my second mod, the kooks long tube headers install.
Oh yea I am not a mechanic and I do not work on cars, But I can read and read with comprehension the instructions from kooks were written very good…
Before I start let me tell you this was very time consuming almost all the bolts had to be wrenched all the way off and most of them had thread locker on them.
Now let’s get to the install
The first thing you should do is get yourself 4 jack stands and a floor jack (borrow from your friends if necessary) pic 40
When you jack up your stang do the back first(pic 41) a little then set the 1st pair of stands under the axel close to the wheels(pic 42 & 43), then let the car down on to stands and then to the front,
When you jack up the car from the front you will have to find the cross member, located directly under the engine in front of the oil pan (do not jack up on oil pan) do this till you get the car at the height you want (for me it was about 16”) make sure the car is level once you’ve got it jacked up
