leak oil
ok been couple weeks with my new intake, seems back of block pushed a cork gasket out and is leakin a lil bit oil down block.......sooo i get to take it all apart and re seal it again........so gasket to use felpro 1250???
seems drip is from passenger side rear of were block and intake section mates up.......so should i just use silicon gasket or use the cork as well??? this car is more then a pain in my ass at times........what should i do/use so i can be done with it 1 more time. ![]()
89 Coupe....Vrooommmmmm Vrooommm 302 bored .30 over ford 3.400 stroker crank, H-beam 4340 rods, hypertech pistons, Aluminum AFR heads with head studs, Trick Flow Track Heat, 1.7 Roller Rockers, 284 duration, .480 lift hydrolic roller cam, BBK long tubes, x-pipe, dual flows dumped, MSD coil, Texas Motor Sport Hp seriers T-5, 70mm Throttle Body, Power Pipe, K&N Filter...bla bla bla HP 335/ TQ 361 to the ground dyno tuned by PSI. all below 5500rpm, went flat...needs bigger cam. |
run a layer of silicone... they dont sell a rubber gasket for these cars? that sucks... i haven't built mine yet, and it's been a long time since i have built one..
Dont use the cork at all. Run a bead of RTV (silicone) acroos the front and back as well as a light bead around the water passages from head to intake. Carefully set the intake straight down into place try to avoid frt to back movement torque her down as per the sequence and all your troubles will be over.
nice tip don. it seems as popular as these motors are, they'd make a rubber gasket for them.. that really agrivates me now.
Just Race
My personal profile and my .02 ![]()
Thanks guys.......live and learn right.....
ok done again..........gasket stuff on........car runs great.....got my fingers crossed no more leaks on the rail.
#10 | |
What's it gonna be?
I'd also get a new PCV valve and the grommet that it sits into on the intake, that is another hot spot for oil leaks on your engine.
#11 | |
Box Foxes Rule!!!
also.
Never underestimate the unpredictability of stupidity! 82 Granada Wagon,306/C4/brake/4.30s=fun! |
I'd use silicone as well instead of those shitty cork gaskets . Black works well as does copper .
![]() When the lights drop , the bullshit stops .Texas Motorsports Myspace Texas Motorsports Photobucket |
