Old 08-05-2007, 08:37 AM   #1
Humble Pie (18-1)
Stang6uy's Avatar
lincoln mark7 brake problem
Ok I have a 90 LSC that the rear calipers were froze up so I changed them out...brakes, calipers, and pads....well we went to bleed them with no success. Does anyone know if this car needs to be hooked up to a scanner to allow it to bleed the brakes...fluid dripped out of the brakelines...just not compressing them now..
1983 GLX Blu-sold
1989 Blk coupe-sold
1990 Blu hatch-crushed
1993 white vert-sold
1985 gt hatch white-sold
1990 Blk coupe-sold
1990 Blk coupe-sold
1990 red hatch-sold
1995 yellow gt-sold
1996 Blk gt-sold
2000 Blk gt- DD
1990 Lincoln LSC----->new project
Old 08-06-2007, 12:12 AM   #2
keg65's Avatar
how did you bleed them?
Old 08-06-2007, 10:32 AM   #3
Humble Pie (18-1)
Stang6uy's Avatar
I couldn't it would not let me do the rear for some reason....I took the brake lines off and everything drained out....so I refilled and tried but felt the same as before I did the new brakes, roters, and calipers....and the anti lock brake light is on and the brake light...not sure if this is the real prob....and what it would be..
1983 GLX Blu-sold
1989 Blk coupe-sold
1990 Blk coupe-sold
1990 Blk coupe-sold
1990 red hatch-sold
1995 yellow gt-sold
1996 Blk gt-sold
2000 Blk gt- DD
Old 08-07-2007, 09:51 PM   #4
Sounds like air in the ABS valve which is a bitch to get out from what I hear.
Old 08-11-2007, 08:38 PM   #5
I bet your master cylinder is going bad since you cant get any fluid to the rear. There is no automated ABS bleed procedure for that car.
Old 08-12-2007, 10:19 PM   #6
Humble Pie (18-1)
Stang6uy's Avatar
don't think so...all I know is I changed everything out and there was fluid leaking out of rear lines....but the pedal just feels hard and won't go down any further....you pretty much have to stand on it to get it to stop...
1983 GLX Blu-sold
1989 Blk coupe-sold
1990 Blk coupe-sold
1990 Blk coupe-sold
1990 red hatch-sold
1995 yellow gt-sold
1996 Blk gt-sold
2000 Blk gt- DD
Old 08-21-2007, 12:48 PM   #7
Jus Workin Away !!!
txlen's Avatar
UNHOOK THE BATTERY, FILL THE M/C WITH FLUID, AND LET THEM GRAVITY BLEED FIRST....KEEP A WATCH ON THE M/C FLUID...DON'T LET IT GO DRY, THEN BLEED THEM LIKE NORMAL WITH THE BATT STILL UNHOOKED...OR GO SOME PLACE AND HAVE THEM PRESS BLED..
Old 08-21-2007, 03:59 PM   #8
Humble Pie (18-1)
Stang6uy's Avatar
thanks for the info...
1983 GLX Blu-sold
1989 Blk coupe-sold
1990 Blk coupe-sold
1990 Blk coupe-sold
1990 red hatch-sold
1995 yellow gt-sold
1996 Blk gt-sold
2000 Blk gt- DD
Old 08-21-2007, 07:22 PM   #9
4.6stanger's Avatar
did it work?
Old 08-22-2007, 06:53 AM   #10
Is that a mach?
y2kGT's Avatar
did you use new brass o-rings in the rear? If not that is prob. y!
Y2kGT-Just another 4-6
1995GTVERT-DD
1989LXVERT-waiting to be reborn!
y2kGT is offline   Reply With Quote
Old 08-22-2007, 08:23 AM   #11
Humble Pie (18-1)
Stang6uy's Avatar
Originally Posted by 4.6stanger View Post
did it work?
haven't been able to try it yet....I am in SA and the car is located in CC right now...but I will this weekend...also I did use new brass rings...
1983 GLX Blu-sold
1989 Blk coupe-sold
1990 Blk coupe-sold
1990 Blk coupe-sold
1990 red hatch-sold
1995 yellow gt-sold
1996 Blk gt-sold
2000 Blk gt- DD
