Old 05-03-2008, 02:32 PM   #1
little help please settle an arguement
well the other day a friend and i were talking and he said that i could fit the frpp whipple for the lightning on my gt.i said that it couldnt be done the intake ports were farther away cause of the slightly larger block thus it would not fit. he said they are the same thing 4.6 to 5.4 help porfavor
thanks
fatman
baddest is when your capable of beating the baddest
the_fatman is offline   Reply With Quote
Old 05-03-2008, 02:49 PM   #2
Stroked and Procharged
04Roush2's Avatar
Send a message via MSN to 04Roush2 Send a message via Yahoo to 04Roush2
Just tell him he's on crack
http://www.myspace.com/charliepr
http://www.sinisterstangs.com
Originally Posted by Ryan_65Stallion View Post
lol. I love you to Jody
04Roush2 is offline   Reply With Quote
Old 05-03-2008, 03:56 PM   #3
Bird's Avatar
The only way it'll fit is if you have a 5.4 2v in your GT. Your friend obviously doesn't know the differences between a 4.6 and a 5.4.
Bird
2001 F-150 Lightning - Bassani Exhaust, Hotchkiss TVS suspension, 14# boost, Shreve Performance tuning
93 Ranger Splash - SOHC 4.0, C4, M-112, Auburn 4.10 LS - it's finally running!!!
Bird is offline   Reply With Quote
Old 05-04-2008, 09:57 PM   #4
I eated it..
Trader Rating: (14)
Countless stories on this particular question on multiple forums. A quick google will reveal that...
In short, and as stated, will not work.
Old 05-05-2008, 04:30 PM   #5
why would you do such a thing anyways.
sure you could get a fabbed lower intake manifold and cut a hole in your hood.... relocate a bunch of parts... but why?
