little help please settle an arguement
well the other day a friend and i were talking and he said that i could fit the frpp whipple for the lightning on my gt.i said that it couldnt be done the intake ports were farther away cause of the slightly larger block thus it would not fit. he said they are the same thing 4.6 to 5.4 help porfavor
thanks fatman
baddest is when your capable of beating the baddest |
#2 | |
Stroked and Procharged
Just tell him he's on crack
![]() ![]() http://www.myspace.com/charliepr http://www.sinisterstangs.com Quote:
The only way it'll fit is if you have a 5.4 2v in your GT. Your friend obviously doesn't know the differences between a 4.6 and a 5.4.
Bird
2001 F-150 Lightning - Bassani Exhaust, Hotchkiss TVS suspension, 14# boost, Shreve Performance tuning 93 Ranger Splash - SOHC 4.0, C4, M-112, Auburn 4.10 LS - it's finally running!!! |
#4 | |
re re
Countless stories on this particular question on multiple forums. A quick google will reveal that...
In short, and as stated, will not work.
why would you do such a thing anyways.
sure you could get a fabbed lower intake manifold and cut a hole in your hood.... relocate a bunch of parts... but why?
