LT question
alright i am going to put mac long tubes on my 99.
i was wondering if i just needed the 02 sensor extension wires?
Gutzy ![]() 99 v6 silver stang black bullits Mac Lt's Mac o/r H pipe Flowmaster super 40's SCT XCAL2 Ebay CAI Mach1 chin spoiler steeda tri-ax |
re re
You will need them, but you can add the length your self if need to to save that cash on buying a set. Just do the wires one by one and insulate the crap out of them. Cut the wire, add your needed length, splice and solder them, tape them, add wire loom, and tape again.
Supercharged
Its not hard, at all....
#8 | |
I'd strongly recommend soldering any spliced wires; you'll never have problems with them that way. If you use crimped-on connections only, you could develop intermittent problems if a connection works loose.
-- Mike -- 2005 V6 Automatic, 300+ RWHP Vortech Supercharger, air-air intercooler, blow-through setup; 42#s; maf.ia; 40mm BOV; PLX Wideband O2, VEI digital gauges, SOS pillar pod; JBA 9MM wires; 3.73s, T-Loc., LPW girdle, alum driveshaft; Steeda panhard bar & brace, CHE lca's; Mac LT headers, high flow cats ![]()
yeah i planned on just putting the LT's in myself and making the extenders and Mills. hopefully it will all work the first time
![]() does anyone know the easiest way to put the Lt's in?
#10 | |
re re
On a V-6 not too bad, but still a PITA. Raise the engine or drop the k-member to help.
dang that sucks!! soo i guess this wont be a one day kinda thing at the house on jacks
#12 | |
re re
If you don't have any experience or never have done one before, I'd make it a weekend project using a small supply of tools, jack stands, and a friend or 2.
well i have experince with working on cars since i built my old bronco from the ground up but havent done much on my mustang other than a tranny swap. And i will have at least 2-3 people there to help me; with all the tools i need. So yeah i guess it will be a nice weekend project
#14 | |
re re
V-6 is much easier then the V-8, but a k-member gives you tons of room for long tubes.
ok thanks i will make sure to go ahead and take it off.
#16 | |
re re
Do a google on it, there are tons of write ups and how too's as well, but more for a V-8 since it is more common.
#17 |
You do not have to raise the engine at all. Get the car as far up in the air as possible and slide the longtubes in from underneath. You will probally need another healper for this. Don't forget the new exhaust manifold gasket, exhaust leaks =
HI! Forged and stroked 4.3L V6 |
#18 | ||
re re
#20 |
greg do somethin yourself for once
