Old 08-20-2007, 07:08 PM   #1
2002 Saleen, S281-SC #261, Silver on Black
SyberSaint's Avatar
Send a message via Yahoo to SyberSaint
Mach 1000 install
Hello All I thought I might share this with you...
I just got my Mach 1000 wired in last week. If any of you are looking to upgrade your Mustang's system, but do not want to get rid of your stock look, the Mach 1000 is the way to go. I bought the head unit, subs, and amp rack from a guy on ebay. The new Mach 1000 head unit was a direct plug and play switch out for the Mach 460 head unit. However, you have to make sure that the head unit is from the same year car that you have. Somewhere in late 03 or early 04 the plugs in the back changed, but if you just wanted to use your original 460 head unit you can, and it will still work fine. To do this, find a Mach 1000 amp rack, and subs like you see in my trunk (make sure the factory harness is on the amp rack). Make sure that you also get the mounting brackets, AND nuts that belong with them. Then, go to ebay and there is a guy on there that sells a small splicing harness. This harness allows you to intigrate your amp rack and subs to your existing 460 wiring (this harness is needed). It comes with all of the connectors, wiring, and instructions to get your amp and subs working... My stereo hits great and I love it much better now. Any of you want to hear it before getting one, I go to biffs... Just PM me and I'll make sure I'm there for you to take a listen... I am sure that there are better aftermarket systems out there, but this is for the person who whats to keep their system stock looking and still get great low end HITS...
Cheers,
Dale
Mods:
1. Stainless Bumper Inserts.
2. Bullitt Fuel Door.
3. Magnaflows.
4. BBK Ceramic Coated Long Tube Headers.
5. BBK catted X-Pipe.
6. FMS 3.73 Gears.
7. Tunable Cold Air Intake.
8. ChicaneSport 66mm Underdrive SC pully.
9. Steel Crank.
10. Forged internal.
11. Cobra Fuel Pump.
12. Spec Stg 2 Clutch
13. Tach installed in AC vent
14. Roush Tool Kit
15. MGW Shifter
16. Mach 1 Grill Delete Kit
17. MGW chrome interior trim knobs, buttons, and instrument bezel.
18. Firewall Adjuster
19. MRT Hood Struts
20. Mach 1000
21. Saleen Rearend cover.
22. MoSaleen's SC Idler pully
23 SCT X Cal II Tuned by Murillo Motorsports
SyberSaint is offline   Reply With Quote
Old 08-21-2007, 11:54 AM   #2
Is that a mach?
y2kGT's Avatar
how much did that set up cost u on ebay?
Y2kGT-Just another 4-6
1995GTVERT-DD
1989LXVERT-waiting to be reborn!
y2kGT is offline   Reply With Quote
Old 08-22-2007, 07:06 PM   #3
SyberSaint's Avatar
y2kgt,
I got the headunit, amp rack, subs and hardware for about $625.00. Just type in a Mach 1000 search in eBay...
Dale
Mods:
3. Magnaflows.
6. FMS 3.73 Gears.
9. Steel Crank.
14. Roush Tool Kit
15. MGW Shifter
19. MRT Hood Struts
20. Mach 1000
Old 08-22-2007, 07:13 PM   #4
Is that a mach?
y2kGT's Avatar
cool....if I end up with n e money I can begin looking for one!
1995GTVERT-DD
Old 08-24-2007, 10:23 AM   #5
the wheel goes round
CrewChiefLite's Avatar
Trader Rating: (4)
I just want a sub box, but nobody will split them up
Car
Car
Car
Truck
