Old 02-19-2008, 09:27 PM   #1
sexystang89's Avatar
Unhappy major problem on my motor
came from the coast this pass sunday. on the way home my motor started shaking the next thing you know i started losing power. I pulled over at the next rest area i check the sparkplugs and all four on the driverside were loose not knowing how bad they were burn i just tighted them up and turn the truck on. it stayed shaking but i needed to get home before dark ,because of my kids, so i forced it all the way home. as soon i got home the truck turned off and that was the last time it turned on. i replaced all the sparksplug because the four that were loose melted on the tips. it still dont start but i check the oil because the oil gauge didnt move and it smelled like fuel! i hooked up the computer and it told me that cylinder 1-4-8 were misfiring but i have no clue. it didnt smoke it didnt knock. please help me with your honest opinion thanks for taking the time for reading this!!!!
sexystang89 is offline   Reply With Quote
Old 02-19-2008, 10:25 PM   #2
Lifted78Chevy's Avatar
do a compression test on all the cylinders to see if there toast or not....
1989 LX Coupe 5.0
Tuned at PSI.pulled threw 5800 no stop shut it down at 6 grand....
Next motor all out with it...hope make 6-7 hundred hp
Old 02-20-2008, 03:06 PM   #3
LOL @ your mom
Trader Rating: (21)
I assume this is a Ford truck with a mod motor right?
Misfires on 1, 4 & 8 are opposite banks. 1 & 4 is on the passenger side and 8 is on the driver side.
Old 02-20-2008, 11:45 PM   #4
It's LOUD but YOU looked!
stangfreak's Avatar
do a compression test and check your plug threads.
4.6 are known for blowing spark plug threads. if you did you will have to have thread buckets put in. (rebuild)
Deep thought...
Why do they call it an asteroid when it's outside the hemisphere, but call it a hemorrhoid when it's in your butt?
