Old 07-25-2006, 03:45 PM   #1
manual tranny fluid change on 02 gt
I want to change my manual fluid on my 02 gt but don't know how.... any input
thanks
blackhawkgt
blackhawkgt is offline   Reply With Quote
Old 07-25-2006, 03:59 PM   #2
Should be a drain plug in g=the center of the bottom. remove it and drain fluid. Refill thru plug on the side (p/s of trans) should hould 3.2 qts if I recall correctly. Also these use ATF not gear oil BTW. U have many chioces of brands depends on what ya want. U can refill thru he shifter if U have it out as well.
Old 07-25-2006, 04:23 PM   #3
Feelin good like a mescan should
SiLv3R_4point6's Avatar
Send a message via AIM to SiLv3R_4point6 Send a message via Yahoo to SiLv3R_4point6
I was under the car sunday and didn't see a drain plug. Was it near the tranny cross member? I have a real bad leak theres fluid all over the end of the tranny.
Myspizzace
SiLv3R_4point6 is offline   Reply With Quote
Old 07-25-2006, 04:29 PM   #4
is this it?
Myspizzace
Old 07-25-2006, 11:26 PM   #5
Check ya later!
Originally Posted by SiLv3R_4point6 View Post
Yes.
