Results 1 to 5 of 5
Thread: map sensor question
    LSS Regular Regular Member
    Jun 2010
    rio grand valley--the real south texas
    map sensor question
    i got a little 308? i think,302 bored .040 over, with trick flow heads and stage 2 cam blah blah blah, i don't have a map sensor at the moment, is it necesary to have one?
    fox-man Regular Member sticks905.0's Avatar
    Aug 2005
    san antonio tx
    i im sure its a no brainer the map sensor has to read the vacume. so with your set up im almost positive you need. "dont quote me" someone else will chim in im sure
    Dec 2007
    Marion
    Is your car a speed density car or MAF car? If it is a speed density car you will need a MAP sensor and hooked up and it will run like shit with that cam without a tune. If you have MAF, the part that is called a MAP on a speed density car is called a barometric pressure sensor, it is the same part, just does not have a vacuum hose hooked to it, the port is left open, but it does need to be plugged into the computer harness. It tells the computer what the air density is, a MAP does the same thing right before the car starts, then registers manifold vacuum. If you leave either a MAP or a Baro sensor disconnected, the car will run very rich.
    Aug 2005
    san antonio tx
    and there you go!!!! good stuff sonic
    Jun 2010
    My car was a 4 cylinder. the harness came out of a 91 gt. Hopefully I can get this thing to ya soon Ron! Thanks again!
