Old 05-24-2008, 05:20 PM   #1
blk01gt's Avatar
Send a message via AIM to blk01gt Send a message via Yahoo to blk01gt
missing
i did a plug change on the car and it started missing every once and a while. all the COP's are on tight and connections are good. ill be driving and it'll be fine then it will miss a few steps and pick back up and be ok??? im pullin my hair out on this one... any ideas
blk01gt is offline   Reply With Quote
Old 05-24-2008, 05:22 PM   #2
Don't hate!
Trader Rating: (20)
Crack a plug perhaps??
Moisture in the plug bore??
Old 05-24-2008, 05:26 PM   #3
blk01gt's Avatar
maybe im prolly gunna pull em' and see if not replace them again..
Old 05-24-2008, 05:27 PM   #4
Don't hate!
Trader Rating: (20)
Have you gotten a MIL yet? And if so, just scan it, see where it points on a misfire code and make life easier.
Old 05-24-2008, 05:38 PM   #5
blk01gt's Avatar
nope no mil
Old 05-24-2008, 06:30 PM   #6
Evil Angel
Bigdrumma22's Avatar
Just a lil' info... When mine was misfiring, it took it a while before it popped the MIL. I think it was at least a week... actually no... now that I think about it, I don't think it popped a code at all. I took it to Jody when he was at his former employer and he scanned it to find my #3 cylinder was misfiring. He called the misfire before he even scanned it... he's kinda good like that. The misfire was due to moisture in the bore as he mentioned. Good luck!
Old 05-26-2008, 01:39 AM   #7
4 valve FTW
seco's Avatar
go ahead and check the resistance between the secondary terminals on the
COPs. Should read around 5.5k ohm resistance. Jody suggested a weak COP
when I was having problems and he was right. It was a bad COP for cyclinder 5 which
measured around 8k ohms of resistance. I had problems with interm misfire for about a year
when no check engine - finally nailed it after getting consistent P0305
