Old 12-05-2003, 04:23 PM   #21
EWP
EWP's Avatar
Send a message via AIM to EWP
good luck justin, hope the new dist. works out for you.
so when you puttin a turbo on the car?
EWP is offline   Reply With Quote
Old 12-05-2003, 04:55 PM   #22
Ooh-Rah Marine Corps
dcm4136's Avatar
.035 is a good start for the plugs.
88 vert
Old 12-05-2003, 05:56 PM   #23
roller4v's Avatar
Please let us know if it fixes things for you. I'm really curious what the problem is.
Steve
1983 GT 5SP,
1988 LX 5.0 AOD Hatch
roller4v is offline   Reply With Quote
Old 12-07-2003, 05:23 PM   #24
Send a message via AIM to 4eyedhatch
well im still workin on it, i gapped the new plugs to big so i pulled em out to re gap them, and they were soaked in gas so i let the car sit overnight with out the plugs in, im about to put it all back together, fingers crossed
351w
4eyedhatch is offline   Reply With Quote
Old 12-07-2003, 09:23 PM   #25
welll the plugs keep fouling out so i left them out while i cranked the motor and i saw gas spray out of all the spark plug holes on the passenger side, this is normal right?
351w
Old 12-08-2003, 06:43 PM   #26
☆★LSS★☆
If you set the points they should be set at .017 at the top of the cam.If you are setting it with a dwell meter it is from 28-32.!:jeff:
Old 12-08-2003, 10:24 PM   #27
well now i have an electronic distributor, i think the problem was the power valve in the carb, however now when i crank the motor it backfires through the carb. what does this mean and how do i fix it.
351w
Old 12-09-2003, 07:49 AM   #28
☆★LSS★☆
Sounds like the timing is off.:jeff:
Old 12-11-2003, 03:54 PM   #29
yep, unfortunately ive done all i know how, i guess its time to call in some help.
351w
Old 12-11-2003, 05:36 PM   #30
☆★LSS★☆
Where are you located?I'm positive I can get it running!For a small fee!:jeff:
Old 12-12-2003, 12:05 PM   #31
got it running last night, strange though cuz i didnt do anything new, i just pulled out the dizzy put it tdc again, dropped in the dizzy, put in the plug and fired her up, i was amazed. but there is a down side when it fired up, somehow it was in reverse so it jumped back and hit my neighbors car SSSSHHHHH!
351w
