nope i set it in and turned over the motor so the cam would pull it in then i cranked the motor to get i back at tdc and saw that the rotor wasnt moving so i pulled out the dizzy and it was broken, same thing happened again when i put the stock dizzy in.
351w |
nope, not at all, but obviously there is a serious problem goin on here, the motor does spin clockwise correct, which makes the distributor spin counterc clockwise, how could that gear possibly break off like that?
351w Last edited by 4eyedhatch; 12-14-2003 at 09:55 PM. |
its a rebuilt motor from o'reillys, i think its a couple of years old, but rarely driven, i was told when i bought the car that it had 2500 or so miles on the motor, so about 3500-4000 miles
on it now
351w |
Sounds like you have the wrong distributor gear on the cam or the wrong distributor gear. Both gears are supposed to be a certian metal (I forget now) also.
![]() 1988 Mustang LX |
#9 | |
I bet the distributor gears were brass:gil:
My friend thought he had a billit gear on his 351 Distributor but found out the hard way. Car died at the end of the track and upon inspection the cam chewed the Brass gears off the distributor.
"it's just a 302" Quote:
![]() Last edited by Sick88lx; 12-15-2003 at 08:58 AM. |
nope, it didnt turn. looks like i have to pull the motor, or at least lift up a little to get the oil pan off.
i like to look at my guages while i drive and the oil pressure never dropped the car just shut off so im hoping nothings damaged.
351w |
At the very least after installing the new pump fill it with straight 20w and a filter run it for like 5 mins (idle) and drain and change the oil. Just a suggestion.:jeff:
#16 | |
Guest
Posts: n/a
:gil: |
