Old 07-06-2004, 10:22 AM   #1
The token Asian guy
propellerhead's Avatar
My review of the One Touch Down Module from PonyPerformance
This past weekend, I installed the One Touch Down module from Pony Performance. It adds the one-touch down feature to the passenger side window, just like the driver side window. One quick press of the window switch and it will roll all the way down.
The module takes 15 minutes to install, or 30 if it's your first time and you're double and triple checking everything. Installation was really simple. Pry open the top part of the trim that holds the window switches, then pull the entire trip piece up. There's one clip near the rear end holding the trim piece in. Find the right colored wires and tap into them using the connectors provided. There were two or three wires to connect using crimp on connectors. There's one wire to cut and two crimp on barrel connectors are provided to make clean connections. One wire had to be grounded to the door. I attached the loop fastener (also provided) for the ground wire to an existing screw in the door. The only tools I needed were a flat blade screwdriver to pry the trim away from the door, a crosspoint screw driver to attach the ground wire, and a wire stripper/cutter. I also used a multimeter because I was paranoid and wanted to double check all my electrical connections. The control module itself does not have to be attached or bolted to anything. I just wrapped it in one of my spousal unit's socks to prevent any rattles, and lodged it between the door and the trim.
Once installed, I can click the either switch (driver's door or passenger's door) for the passenger side window and it will roll all the way down. Pressing the switch again while it is rolling will stop it.
The instructions cover both 99-04 and 94-98 installations. The kit costs $27 shipped. The website only takes Paypal, which I don't have so I mailed a personal check and received the kit in less than a week. The owner of the business is really good at responding to emails.
Overall, I say
Link to item: http://www.ponyperformance.com/specials2.html
Disclaimer: I do not work for PonyPerformance or am I associated with them in any way other than as a satisfied customer.
Edit: Typos.
2004 Mustang GT
Old 07-07-2004, 08:36 PM   #2
DUDE, I LOVE YOU MAAAAAAAN!!!! (remember the old budweiser commercials?) i have been looking EVERYWHERE for a one touch passenger side window switch. thanks a lot for the link.
edit: this works on a 99+ GT right?
2000 Laser Red Mustang GT M5 Pics and Mods
-K&N FIPK-Steeda TA-Steeda Tri-Ax-FMS 4.10 gears-UPR O/R X Pipe-Flowpaths Dumped-Eibach Sportlines-Tokico Premiums-Pro3i C/C Plates-HPM UCAs & LCAs-Custom F/L SFCs-Steeda STB-Steeda Adj. Rear Swaybar
-full audio system/alarm
13.724@101.01 w/ a 2.0 60' on a stock suspension and street radials
derekstanggt is offline   Reply With Quote
Old 07-07-2004, 09:12 PM   #3
The token Asian guy
I installed it on my 04 GT. I can hit the passenger's window switch on both the driver's door or the passenger's door and it will roll the window down. I love it. I drive with both windows down a lot and it's nice to bump both switches at the same time and let go.
2004 Mustang GT
