I think he likes you...
MY STEREO STOPPED WORKING...
I was driving, heard a tiny pop that I usually hear when I turn off the car before the radio shuts off, then the radio (its aftermarket) went into its shut off mode and turned off..hasnt turned on since...and i cant drive without any tunes...any ideas???
Update:just found out on the way home that my windshield wipers dont work either...
http://www.myspace.com/4652469 Last edited by ImpactStang; 01-29-2007 at 11:11 PM. |
if you bring it to me, i'll check it out.. could be a million and three things.. everyone will tell you 10 things to check... just let me know if you want me to look at it... free all day after 9 am tomorrow
dang well i work all day tomorrow from like 11-9...would there be easy things for me to check now that you know of?
http://www.myspace.com/4652469 |
yea fuse is a possibility... and keep in mind depending on the radio.. there's normally a fuse in the back of the head unit covered underneath the plug
do you happen to remember which one? I have had my head unit for a long time and have not had a problem until yesterday....it makes drivin the stang less pleasureable...
and im guessing theres no way to get to that one without taking the head out right?
yup, you'll need to remove the radio to get to the fuse (if its there).
Once its out you also need to check to make sure you have 12v power to the red and yellow wires. If not check the fuse for that circuit. If you do have power , check the radios ground ( just because). And if its still out then it took a crap and you need to get a new one.
GO SPURS GO
yea you know alla bout that jamison.. but yea.. once again, if you like i can look at it.. if you want gimme a call after work and i'll take a look.. i'll pm in a minute
hell...not when im waiting on a house...maybe after though...
#16 |
got a fuse changed out, stereo doesnt sound as loud and the wipers dont seem to be going as fast but they work...
