Its about almost a year since I last posted here. Still in the Air Force, now stationed in Las Vegas, Nellis AFB. Since the re-enlistment and the move, I was able to pick up a good chunk of money, which went into the build. Think the last time I posted, I only bought a few major modifcations, and left it at that. Now, the cars build is almost done. The stroker has been payed for in full for both parts and labor to get it together, now to strip the car down from all the V6 stuff and upgraded to the GT or Terminator parts I bought for it. Should be the next month or so, and itll be ready for a few dyno pulls then a track date. Since Im not at home, the work is being done by a real good friend of mine, been building race cars for a good time now, though I think Im his first V6 car to work on. Were both pretty stoked at the outcome so far. Heres some details and pics for kicks..
P1SC Procharger w/ 3-Core Intercooler @ 15psi
SSM Long Rod 4.3L Stroker Rotating Assembly
SSM Stage 3 Ported Cylinder Heads 1.94/1.56 Valves
SSM Stage 3 Ported Lower Intake w/o IMRCs
SSM CompCams 224/230 .54/.54 114 Lobe Sep. Billet Cam
SSM CompCams Stud 1.7 Roller Rockers
Precision Industries 3000RPM Stall
'97 Ford Windstar Upper Intake Manifold
60lb Injectors
Kenne Bell Boost-A-Pump w/ Upgraded Wiring [40amp]
Fore Precision 03/04 Cobra Dual Pump Fuel Hat
2003 Cobra Dual Pumps
2003 Cobra Fuel Tank
Morana V6 Racing 3.8L/4.2L Main Girdle
VAP Auto J-mod Shift Kit
VAP Auto Intake Spacer
Diablosport MAFia
Aluminum Driveshaft w/ Safety Loop
BAER Decela Front Rotors
UPR QA1 K-member
UPR QA1 A-Frames
UPR QA1 Coilovers
Lakewood Struts 90/10 [Front]
Maximum Motorsports 4bolt Caster Camber Plates
MAC Longtube Headers
Custom PVC Pipe Cold Air Intake w/ K&N Filter
Airin 25mm Throttle Body Spacer
70mm Power Throttle Body
9mm Ford Racing Spark Plug Wires
Rebuilt 8.8 Rear End / 4.10 Gears
haha
