Old 03-05-2008, 08:14 AM   #1
Need a tremec 3650 and or clutch
Hey fellas I need a good 3650 for my 01 Cobra for not too much coin. I possibly blew it up last night. Also I need a good clutch with throw out bearing. In or around San Marcos would be preferable. Call me @ 512-922-8042 Brandon
no cigar is offline   Reply With Quote
Old 03-05-2008, 08:35 AM   #2
thesource's Avatar
Trader Rating: (12)
If you can't find something used on the T3650 , let me know . I can rebuild it but its not going to be cheap . Those damn parts are high dollar for the T3650 units .
Old 03-05-2008, 09:11 AM   #3
speed-olic
machgsxr's Avatar
Trader Rating: (7)
I have one, but it has a bad 3rd gear syncro. All other gears worked fine, you just had to work it to get it to go into third.
Im going to Austing Friday night as well so I can deliver it if needed.
Old 03-05-2008, 09:22 AM   #4
thesource's Avatar
Trader Rating: (12)
Thats the most common issue with them but I have seen a few lately that were a lot worse off too .
Old 03-05-2008, 11:46 AM   #5
i have one from a 'wrecked 04 mach 1 for $700. comes with trans, t/o bearing, clutch, p/p, MGW shifter, clutch cable, and flywheel. supposedly had 65,000 miles, and was working fine. a mechanic wrecked the car after doing a tune up.
rxracer is offline   Reply With Quote
Old 03-05-2008, 10:03 PM   #6
You have a PM
Old 03-12-2008, 01:26 PM   #7
Hey fellas, I got it taken care of, sorry for the late notice.
Archie, you are a life saver man! Thanks a LOT! Also, no problem about not being there to load it - but tell your sister thanks again for helping me out.
Old 03-12-2008, 02:45 PM   #8
speed-olic
machgsxr's Avatar
Trader Rating: (7)
Cool. Will do.
You get your car back to C.c. alright?
Old 03-12-2008, 03:19 PM   #9
Sure did. Even with that synchro it shifts smooth and runs great. Thinking about rebuilding it because it has the .62 o/d... Mine had the .68.
Old 03-18-2008, 10:16 AM   #10
Send a message via AIM to RedIceATX
Yeah, I am on my 2nd one and that happened on the first tranny as well as this one.
Can you PM me the cost on parts for that?
RedIceATX is offline   Reply With Quote
