Old 05-03-2004, 11:35 PM   #1
the anti-rice
need advice on lowering my car!!!
hey,,,im plannin on lowerin my car about 2 inches...and dont know much about what it takes or what its gonna cost... ive got all stock suspension..and word on the street has it that you can "cut" your existing coil springs in order to lower the car.. what all would it take to lower the car 1.75 to 2.00".......
00' five speed, throttle body spacer.. exaust...intake... gt rims with 275/40/zr17 sp sport 5000 tires...20% tint..bumper inserts..spoiler moved back 3".....pics on the way!!!!!
3.GREATWHITE is offline   Reply With Quote
Old 05-03-2004, 11:43 PM   #2
Adrock For President '08
timpryor's Avatar
DO NOT CUT whatever you do look around and find some lowering springs and do it the right way T.J.,that is all im going to sleep now
P.S. unless you wanna bottom out on just about all lg. speed bumps i wouldnt do more than 1.5 inches
in fact here is what i am planning to get http://www.gefracing.com/Merchant2/m...y_Code=BULLITT now im going to bed
<><'98 BAB Cobra #3392 of 5174 Modded-446RWHP/408 RWTQ<><
Originally Posted by PonyTx View Post
you scare me.
Old 05-04-2004, 12:35 AM   #3
frostymug's Avatar
I read all kinds of do not cut your springs drivel from all over.
So I went and cut my springs.
Got it lowered exactly where I wanted it to. The ride is really no different than any other I've ridden in with replacement springs. I was expecting alot worse ride than what I got. Worked well for me.
My advice is to go with a backup plan. Set aside money for some springs in case you cut and really don't like it. Stiffer springs are going to ride stiffer. Period. Whether they are cut stocks or lowering springs.
frostymug is offline   Reply With Quote
Old 05-04-2004, 03:16 AM   #4
Ooh-Rah Marine Corps
dcm4136's Avatar
Cutting them will work ok. Lowering springs would be better though. Keep in mind that lowering your car to much can screw up your steering geometry. If you are gonna go for that much drop you probably want to look into getting a bump steer kit also.
88 vert
Old 05-04-2004, 07:58 AM   #5
...So I dub thee Unforgiven.
redrum's Avatar
2 inches wouldnt mess him up really, i wouldnt think. hell, joestang was slammed like friggin 6 inches or something :pickle:
id say your best bet is to go search several forums for pics and see what car sits the way you like it. PM the guy and ask him what springs he has (hopefully itll be a v6) and then you're good to go. and i would think as long as you dont cut the stock springs TOO short, youll be alright, just be aware that when you cut the spring, you're changing the spring rate and all that.
Old 05-04-2004, 08:41 AM   #6
"The Hitman"
Hammered's Avatar
I think there is alot of misunderstanding about cutting springs...The easy way to cut springs is with a tourch..but with a tourch you have to get the metal very hot...which changes the properties of the metal and makes them softer (ie ride like shit) Now if you use a cut off wheel you will not really have the same problem...Cutting a spring shorter should not change the spring rate...
If this is something you want to try ....get some FREE ones from a friend who bought new ones...or a junk yard....or post that you need some...fox body will work on the new cars as well...
As for tim, why the hell would you go with the bullet setup? just get the ford C springs....There cheaper and you do not need that other crap...
Old 05-04-2004, 10:17 AM   #7
if they are progressive rate springs it will...which i believe the rear springs are
My Garage
Old 05-04-2004, 10:34 AM   #8
"The Hitman"
Hammered's Avatar
Thats is the small end that coils down...I think? If you cut the large end, the only one you better cut if you want them to sit on the spring perch, you should be ok...But play with it on the FREEBIE springs...
Old 05-04-2004, 06:04 PM   #9
frostymug's Avatar
Neither front nor rear is a progressive rate spring. The rear ones have one smaller turn at the lower end just so they can fit on the cups.
We used a cutoff wheel and had no problems at all. About 30 minutes for all four corners and another 20 minutes or so to align it. Actual results may vary
The key for any drop is to align it well. Especially toe.
Good luck
Old 05-04-2004, 07:02 PM   #10
AKA silver1988stang
The Diesel's Avatar
Send a message via AIM to The Diesel
Dood, just go to a junkyard and fins some springs off of a 4cyl. fox and swap em. Seen lost of cars do this and it works fine every time. I think i drops it about 1 1/2-2 inches.
XplicitPerformance.com
The Diesel is offline   Reply With Quote
Old 05-04-2004, 11:40 PM   #11
the anti-rice
yea i dont really want new springs cus my car is rough enuf as it is...so ill probably cut them...who can do this and how much will it cost???? will i need new shocks???or is it just cut and go...thankx for the help...
Old 05-05-2004, 12:15 AM   #12
AKA silver1988stang
The Diesel's Avatar
It would be much easier to just buy some old 4cyl. springs for like $15 and have them exactly the same length the first time than to mess uo on yours and not have any springs. I plan on doing this to my stang soon and to a friends.
Old 05-05-2004, 02:35 AM   #13
tire's Avatar
i will check later, but i am 99% sure the rears are progressive... there was a site listing spring rates and other spring specs for V6 coupe, V6 vert, GT coupe, GT vert.
a drop of 1.5"+ on the front will require (if you want your tires to last) a set of caster/camber plates. otherwise your wheels will slant inwards.
if you do want to put some 4 cyl fox springs in the front, be prepared to have a bouncier front end... and it'll brake dive like a mofo. it lowered my v6 coupe at least 2", probably more. when i sit down in it it lowers another 1/2".
Old 05-05-2004, 01:02 PM   #14
the anti-rice
so it would be better to buy some 4 cyl fox springs for 15 bones.. where could i find them for that cheap? and will they work for both front and rear? that seems like alot less work too.. cus its just the install....compared to cutting and getting everything just right
Old 05-05-2004, 03:04 PM   #15
Lingenfelter
VENOMM's Avatar
Send a message via AIM to VENOMM
lowering your car...does that get 75 - 100 hp:woot:
MakingDreamsReal.INFO
**SOLD** 1999 Jeep Wrangler 36" tires LIFTED!!
**SOLD** 2005 Corvette Wide Body
**SOLD** 1998 Mustang Cobra
**SOLD** 2002 Corvette Z06 X1 cam and heads
**SOLD** 1999 Mustang Gt
**SOLD** Dodge Viper RT/10
**SOLD** 03 BMW 325XI
**SOLD** 1994 BMW 325i
**SOLD** 2007 Nissan Titan 36" tires 12" lift
**SOLD** 95 BMW M3 built by Rhine west
**SOLD** 1999 Porsche Carrera GT3
NEW **Lingenfelter Corvette ** 700hp built by Nick Agostino
VENOMM is offline   Reply With Quote
Old 05-05-2004, 06:13 PM   #16
frostymug's Avatar
There is a common misconception that they are progressive due to the one smaller turn on one end. If they were actually progressive the end coils on both ends would gradually get tighter.
Not everything is strictly for horsepower. It will lower the center of gravity and thus make the car handle and hold the road better. Everyone likes to get hung up on HP numbers and toss jokes about anyone doing anything to their ride that does not add to those numbers. Wouldn't it be neat if we all had a car that looked exactly like every other car? Make life easier and give up on having the fastest Mustang now. Unless you are Big Bank Hank. Real Big Bank Hank.
Cheers!
frostymug
Old 05-05-2004, 06:33 PM   #17
Lingenfelter
VENOMM's Avatar
Cheers!
frostymug
na man its a inside joke he said he painted his breaks and it got him 30 hp and he put a sticker on his car and it got him 100 hp and moving his wing got him 2,000 hp bc wind resistance and wind tint got him what...like 100 hp bc it blocks light
Old 05-05-2004, 06:37 PM   #18
nomore stang
jorge morales's Avatar
ok if i buy the 4cyl. springs do i still have to cut or just switch them out with no problem
i dunno
jorge morales is offline   Reply With Quote
Old 05-05-2004, 06:45 PM   #19
Lingenfelter
VENOMM's Avatar
you can just switch them out...i have a place that will cut,install,order ect new springs for anyone thats intrested...PM me There reallly cheat too
Old 05-05-2004, 09:33 PM   #20
"The Hitman"
Hammered's Avatar
I will NEVER work with a CHEAT shop...just my openion
