Old 06-20-2003, 11:58 AM   #1
Man law?
Need advice on subfames
I plan on getting my subframe connectors soon. I am set on getting the powdercoated maximum motorsport full lengths. Were is the best place to order them from? I also need a good shop in San Antonio to weld them in. Any ideas?
thanks.
Old 06-20-2003, 12:08 PM   #2
SassyCassy's guy :P
Send a message via Yahoo to jason10mm
I'm interested in this as well. Toni, can you do SFCs? As for where to order, MM themselves are probably the best spot. Maybe mustangsuspension.com or GEFracing has them though? I'm planning on shipping them straight to the store though, don't think I can haul those in the 'vert!
jason10mm is offline   Reply With Quote
Old 06-20-2003, 12:15 PM   #3
Can I has Procharger?
bandit's Avatar
you guys might also want to consider kenny brown's:
click the pic for more info.
those are the ones that nighthawk got, they are cheaper than MM's subframes connectors and still get the job done with the cross braces and stuff.
-jeff
Old 06-20-2003, 01:14 PM   #4
Coupe Dude
JohnS's Avatar
AB&T transmission in round rock has some killer full length subrames and matrix bracing if you want to go all out.
JohnS is offline   Reply With Quote
Old 06-20-2003, 01:26 PM   #5
MODIFIED
custom built .. and extremely rigid from what i understand.. i waiting to see if he can do some for me so i can have them... since my car is gonna be a pia... and probalby cost a fortune
MAC CAI, Spintech Dual Side exit exhaust, Prokit, 99 GT Rear Swaybar, AGX 5 way Adj., FRPP Clutch, MM Firewall Adjuster, MM Clutch Quadrant, ASP U/D Pullies,MGW Short Shifter, MGW Billet A/C knobs, MGW Locking Fuel Door, Upgraded Seats, Custom Interior Paint, Interior LED Setup, MM C/C Plates, MM STB, Cobra Brakes, Sequential Turn Signals, Saleen Front Facia, Stalker Hood, Sonic Blue DD Bullitts.
Old 06-20-2003, 04:39 PM   #6
LoneStarStangs Addict
Allnuts's Avatar
Trader Rating: (-1)
Can Anybody tell me the dimension for some subframe connector so I could fabricate some, They look fairly easy especially when you have a welding shop.
Old 06-20-2003, 10:46 PM   #7
Do NOT NOT NOT waste your money or time with Kenny Brown SFC's They are paper thin pieces of SHEEEIT.
The MM's are nice, but are pricey. You can make your own, stronger ones for half the price.
I've made and installed SFC's for almost 2 years now, and have YET to see a set stronger than the ones I make. Check out the drawings for the full length SFC's here.... http://www.oldwestracing.com/articles/subconn/subs.htm
A lot of pics here..... http://home.houston.rr.com/blue91/Nancy
http://pomofo.com/SubframeConnectors...y/trkpony1.jpg
http://pomofo.com/SubframeConnectors...y/trkpony2.jpg
http://pomofo.com/SubframeConnectors...y/trkpony3.jpg
http://pomofo.com/SubframeConnectors...y/trkpony4.jpg
http://pomofo.com/SubframeConnectors...y/trkpony5.jpg
Also, check pics in this post.....
http://www.westsidemustangs.com/for...1396&highlight=
(No Im not trying to make a sale... I'm not doing any more for a while. Finally graduated college and trying to get a REAL job.)
Hope this helps!
Regards,
Fred Bingham
http://www.PoMoFo.com
http://www.PoMoFoRacing.com
Blue91 is offline   Reply With Quote
Old 06-21-2003, 10:38 PM   #8
Coupe Dude
JohnS's Avatar
Nice looking work man.:2thumbup:
Old 06-23-2003, 12:03 AM   #9
tire's Avatar
well, if you have your mind made up with what brand you are getting, just make sure that when it is welded that it is done right. stitch-welding is optimal, and try to make the welder do it that way and not just weld the whole seem shut. (they need to be flexible)
Old 06-23-2003, 01:20 AM   #10
Can you give me a reason WHY you think this is correct, and why you think SFC's need to be FLEXIBLE? Or is this just something you've "heard" from someone else?
I'm seriously interested in why this train of thought exists.
Regards,
Fred Bingham
Old 06-23-2003, 01:26 AM   #11
Ooh-Rah Marine Corps
dcm4136's Avatar
I am curious as well. I always understood that the point was to eliminate flex.
88 vert
Old 06-23-2003, 07:29 AM   #12
Allnuts's Avatar
Trader Rating: (-1)
I may understand where he is coming from but not too sure. A mustang or any car with sub-frame connectors will still flex but not as much and when this happens pressure is applied to the sub-frame connector and the body of a car. Also not to mention on the welds or bolts of a subframe connector. So lets say for instance, the subs are weld only on the end points, when the body of a car flexs, if the welds are not strong enought it will break them b/c pressure is being applied to them also in the center of the sub. So if you weld a sub completely, when pressured is applied, it's like having no subframe connectors, the body will twist anyways. I think why there has to be some flexs, this is my opinion only :2thumbup:
Old 06-23-2003, 07:57 AM   #13
Incorrect, but thanks for playing, :P :P
A fully welded set will be MUCH stronger than one that's stitch welded. You don't want FLEX. That's the entire reason you put the SFC's on in the first place. If you put a "good" full length set on, you remove almost all the flexing in the frame. THIS IS WHAT YOU WANT. You don't want the car to flex.
Those Kenny Brown SFC's are so thin, they have been known to BEND while on cars. They don't do much at all to strengthen the chassis, b/c they are so small and such thin material.
Regards,
Fred Bingham
Old 06-23-2003, 01:55 PM   #14
tire's Avatar
Regards,
I'd appreciate it if you don't attack and just question.
Nick from Nick's mufflers in Plano, TX has been doing subframes, exhaust, and other welding for more than 20 years. He is a very knowledgeable older man and he taught me a thing or two while he was working on my car. I don't remember everything he said. He did however say that people would say the same things you are, and that it was still better to do it the stitch way.
Maybe for track cars it should be welded completely on there, but he does them the other way for street cars.
EDIT - my subframes weren't little thin ones. they were rectangular and thick. i got them from a no name company off of ebay for 40 bucks, and Nick said they would be fine for my car.
Old 06-23-2003, 02:32 PM   #15
bandit's Avatar
hmm...perhaps that's the case. drag cars need chassis stiffening for the straight line launches, while street cars may need it for auto crossing and corner carving.
Old 06-23-2003, 02:48 PM   #16
...So I dub thee Unforgiven.
redrum's Avatar
like nighthawk, i am ordering kenny brown subframe connectors later today. toni said he would install them for me (for a price of course). so im pretty sure he would do them for other people as well, just pm him to see what his installation price is for you..
Old 06-23-2003, 03:11 PM   #17
Please quote where I "attacked" you.
Sorry for tryin to steer you guys clear of putting crap on your cars (Kenny Brown, HPM, etc etc SFC's). I obviously know nothing about Mustangs, how the stresses work on the cars, and the strengths of materials involved.
I'm done with this thread, it's falling on deaf ears, heheheehe.
Regards,
Fred Bingham
Old 06-24-2003, 12:37 AM   #18
redrum's Avatar
ok blue91.. if kenny brown isnt good. who is better, and why?
Old 06-24-2003, 11:24 AM   #19
i'm staisfied with the kenny brown SFCs
maybe the super subs are different...cause they're not paper thin
My Garage
Old 06-24-2003, 05:30 PM   #20
Man law?
im getting the maximum full lengths. bare metal though. i have to grind off the powder coating anyway right? so why pay for it. What can i use to coat them after i get them welded on?
