#21 | |
![]() 1988 Mustang LX |
#22 |
Also I believe you will need a seal puller and installer to do it right. Dont forget the pinion flange bolts are 12pt. 12mm and they can get stuck so be prepered.
#23 | |
Stalked!
Whats a seal puller and is there one specifically for each seal? Whats 12pt mean? How can I add ATF fluid until I get this done? Dan |
#24 |
You just need a seal puller to pull the rear seal on the tranny. They can be a pain to pry out with another tool. The seal installer allows you to get the seal driven in straight so it wont leak. A 12pt wrench is a normal boxed in wrench that has 12pts as opposed to 6. PM me if you need more specifics.
#26 |
There is a plug to accept a 1/2" ratchet on the side of the tranny case up high. You can fill it there. Make sure it is the right one because one of them is to hold some of the internals together. Im not sure on your tranny exactly which one it is unless I see it.
#27 |
"The Hitman"
just so you don't waste your money ...the royal purple has the posi additave in it.. for the real end...
Racing in a honda is a lot like the Special Olympics Even if you win, you're still retarded Last edited by Hammered; 02-05-2004 at 10:47 AM. |
#28 | |
#30 | |
Hey, smell my finger
ALSO!!!!!!!, Dont forget to put the t-lok additive for the rear end (friction Modifier!) |
#31 | |
"The Hitman"
#32 | |
Stalked!
#33 |
"The Hitman"
yea i found the answer to the friction adder...it is here
http://www.lonestarstangs.com/forum/...8575#post38575
#34 | |
Stalked!
#38 | |
