Old 08-02-2008, 10:35 PM   #1
Angron2169's Avatar
Need Help Lack of Power
OK I have a 89 Mustang LX 5.0 Worked over to a 306 b-303 cam I have 24lbs and a 75mm Mass Air calibrated for the 24lbs. A Walbro 255 Fuel Pump a new fuel filter and the timing is great ............ My problem is after all of that at full throttle it just bogs out ............. HELP PLEASE
Thanks
Allan
93 Mustang Cobra Clone- Sold
86 Mustang SVO- Sold
90 Mustang LX 2.3T- Sold
89 Mustang LX- Traded
64 Mustang 351W- Dynod 473hp
Angron2169 is offline   Reply With Quote
Old 08-02-2008, 10:50 PM   #2
chiches & nalgas
BigJnSA's Avatar
you still have your cats?
Originally Posted by YZF Voltage View Post
i hate everything... except for hate. i love hate.
Old 08-03-2008, 01:37 AM   #3
whitey92lx's Avatar
are you using any tuning software?
http://westsidemustangs.com
whitey92lx is offline   Reply With Quote
Old 08-03-2008, 09:44 AM   #4
Angron2169's Avatar
yes on the cats ............ no on the tuning software
Thanks
Allan
Old 08-03-2008, 09:49 AM   #5
Angron2169's Avatar
Could the o2 sensors not being plugged in cause this because the previous owner never plugged them in
Thanks
Allan
Old 08-03-2008, 02:54 PM   #6
Check your mass air flow. My 91 was doing the same thing, I swapped it out for another one that I had off of another 91 and problem fixed...
Mystic SVT is offline   Reply With Quote
Old 08-03-2008, 03:27 PM   #7
chiches & nalgas
BigJnSA's Avatar
Thanks
Allan
you may have a clogged cat. that will choke it.
Old 08-03-2008, 03:45 PM   #8
whitey92lx's Avatar
Thanks
Allan
Youre the guy I met this past Friday night out at the 2920 meet!
Old 08-03-2008, 06:03 PM   #9
Brewmeister
coupe5oh's Avatar
yea, need to scan for codes, make sure tuneup items, fuel filter, ignition coil/wire etc..are in good shape.
retired 1990 Tx dps :T-5, stock bottom 302, shorty headers,o-r x-pipe, ported explorer true gt 40 heads, matching intake. E-cam 1.7's, pro-m 77, 24lb injectors, 3.90 gears.
good for mid 12's on stickies.
Old 08-03-2008, 11:48 PM   #10
Angron2169's Avatar
yeah it is me from the 2920 meet trying to get this problem fixed it is killing me ........ all tune up stuff has been done and replaced
Thanks
Allan
Old 08-04-2008, 12:00 AM   #11
whitey92lx's Avatar
yeah, either the cats are clogged up, or you need a good tune..
Old 08-04-2008, 12:06 AM   #12
chiches & nalgas
BigJnSA's Avatar
time for an o/r h-pipe!
Old 08-04-2008, 07:45 PM   #13
XavB's Avatar
i've heard not having the o2's plugged in can hurt your power also. does the car smell really rich? you would probably only want to run the o2's not plugged in if you got a tune for it and even then i've heard mixed answers on whether you want a tune for no
o2s's. plug those things back in as a start, that would be the easiest, cheapest thing to start with.
1992 LX 5.0 - Twisted Wedge heads, Trickflow Stage 1 cam, Trickflow Streetburner Intake, Trickflow 1.6rr's, BBK shorty headers & o/r h-pipe, flowmaster catback, FRPP 4.10s, FRPP 24lb injectors, Granatelli MAF, BBK CAI, BBK 65mm throttle body, BBK FPR, Maximum Motorsports LCA's, CC plates, and strut tower brace, LMM full length SFC's, Mach 1 springs, and Bilstein shocks and struts
XavB is offline   Reply With Quote
Old 08-04-2008, 09:08 PM   #14
whitey92lx's Avatar
Thanks
Allan
I didnt even see this post! Dude, if you dont have your o2 sensors plugged in, your car will RUN LIKE SHIT!
Please get under your car and plug them back in Immediately!
Old 08-05-2008, 10:13 AM   #15
Sonic Blue 85's Avatar
If the O2 sensors are not plugged in it will run rich, if you have other things also causing it to go rich, it could be way too rich. But if the only problem was the O2s being disconnected, it should not cause the car to have a lack of power. Some people don't use them at all, the O2s are only used by the computer when it is in closed loop, so at WOT they are ignored. The MAF could easily be a problem, or could need to be tuned, I have found many Pro M meters that were way out of calibration, to the point they would hardly run, if at all. Do you have an adjustable fuel pressure regulator and if so what pressure is it adjusted to with the vacuum line disconnected?
Sonic Blue 85 is online now   Reply With Quote
Old 08-05-2008, 01:47 PM   #16
Brewmeister
coupe5oh's Avatar
A guy came in to my work for with a cobra kit car, it had an efi 5.0 in it, It would barely stay started, i looked underneath and it had no 02's in it either, I told him, i didnt know how it was running as good as it was.
Old 08-05-2008, 09:32 PM   #17
75mm are prone to be pieces of crap out of no where.
First, make sure the meter is clucked where the electronics are on the outside of the curve of the coldair.
second, throw it away or sell it and buy a pro M 80 and put that puppy in the fender well.
It could be as simple as someone left the spout connector out when they set timing. Do you have a regulator on that bad boy to control that 255 walbro?
Old 08-05-2008, 10:58 PM   #18
Have you done a compression check lately?
fiveohfox is offline   Reply With Quote
Old 08-08-2008, 08:10 PM   #19
Angron2169's Avatar
ok comopression is good fuel pressure is good cats are not clogged we are starting to lean towards the pmas mass air sensor it is calibrated for the injectors just a thought
Thanks
Allan
Old 08-08-2008, 09:59 PM   #20
XavB's Avatar
did you pull the codes? or hook up the O2's?
