yes i know its a stang site but need help on a ford truck...
i have a 1994 f150 4x4 which has a cracked crossmember,,,its the one below the engine and im looking to see if i can buy it new or do i need to go to a junk
yard....
any help?
yard....
any help?
[SIGPIC][/SIGPIC]my stock 03 cobra
The cross memeber under the engine should be riveted in, very likely was nerver available from Ford by it's self, only as a complete frame. It may be difficult to get one from a junk yard also, they will not want to remove that cross memeber from a good frame, if you can find a 4X4 frame in a junk yard that has serious damage to the rear part of the frame, the junk yard that has it would possibly cut the cross member out for you, but you would have to get the rivets out your self. If they did have one with a damaged rear frame they sell you the crossmember if the engine were out of the truck. Getting most junk yards to pull an engine to get to a part like that is not worth the trouble to them. Basicaly you might spend a little time looking for one, but your best bet would be to have the cross member in your truck welded.
thanks for the fast reply...
ive asked around on other sites and have been told about the same
someone already tryed to weld it but didnt do to good
in this pic its cracked from the front bottom at the steering box all the way across the top ,,welding it is ok but how to re inforce it is another
Somebody been beating on that truck a little hard
85GT FACH1 FINISHED
got a chance to stop at a junk yard ..
he let me look around his yard and said if he had one he had no problem cutting the frame up...
well he had 1 ford 4x4 in his yard but i wasnt dressed to crawl under to see if its not cracked,,will be going back tommorrow..
truck has 200+ miles and has pulled a landscape trailer for all of them...my buddy just got it 2 years ago and we have done everything over to keep truck rolling as a dd without breakdowns,,,hes very hard on it but its well maintained
