What year is your car.
your gonna need alot more than just a k member.. I haven't heard of anybody completeing this swap yet..props to you if your the first
custom mounts.. good luck
Snag a 94-95 GT with the k-member and front suspension. Everything should be a direct swap. The hard part will be what to do with the existing PATS system as well as the function of the cluster without swapping in the earlier clusters. Its all do-able it will just take some inginuity and time.
![]() 1988 Mustang LX |
that's awesome.. i had no idea it was that simple...
always asleepn
just sell your car and go buy a v-8 shell much better
91 lx not on the sidelines anymore baby} ![]() 98 gt on the streets. mod motors suk![]() MAD PROPS 2 AnR GOT BOTH MY BEAST RUNNING GOOD. ![]() ![]() ![]()
car is already paid off...and i already have built 5.0 with 347 stroker kit...and plus i want to be different
theres no 99+ stangs here with a 5.0 in it...plus if something breaks..parts are hella lot cheaper than 4.6 mod motors...i know ive had a few |
not a hard swap.
If i was gonna swap a motor in a v6, it would be an ls1 anyways ![]() 94-95 je racing k member if you have a manual, it is alread a t5 you just need to change the input shaft to work with the 5.0. I know a guy in a 3700 pound car going 11.7os on his HC 302 with one. he puls 1.5 60s. slap a complete 8.8 rear in there as well and you can do the uppers and lowers ta the same time.
#16 |
i would go w/ aftermarket guages in a custom cluster.. just my .02 tho..
