Old 06-04-2007, 03:41 PM   #1
need help puttin v8 into my v6 mustang
so i just bought al 5.0 from a guy has all accessories and wiring.. i know im gonna need a k-member right? and what bout control arms?
drastic_measure is offline   Reply With Quote
Old 06-04-2007, 03:49 PM   #2
What year is your car.
Old 06-04-2007, 06:12 PM   #3
its a 2004...
Old 06-04-2007, 06:25 PM   #4
Trader Rating: (8)
your gonna need alot more than just a k member.. I haven't heard of anybody completeing this swap yet..props to you if your the first
Old 06-04-2007, 06:29 PM   #5
custom mounts.. good luck
1991 lx coupe
Old 06-04-2007, 06:34 PM   #6
Cobra OWNS!
swingle007's Avatar
this should be interesting...post up pics for sure!
'05 GT, '97 Cobra vert, and a S/C '87 LX vert
swingle007 is offline   Reply With Quote
Old 06-04-2007, 06:51 PM   #7
i know a guy that had a 2000 gt and did 5.0 swap. but mines a v6 so prolly a lil harder...i can keep my tranny cuz its a t5 already...ill find his article and post it up
Old 06-04-2007, 06:54 PM   #8
My 2000 Mustang GT 5.0 swap(updated with dyno and track times!)
Old 06-04-2007, 06:59 PM   #9
tapitty tap tap
bucho's Avatar
Send a message via Yahoo to bucho
good luck with that swap!!! Yea, wanna see pics too!!!
bucho is offline   Reply With Quote
Old 06-04-2007, 08:38 PM   #10
Snag a 94-95 GT with the k-member and front suspension. Everything should be a direct swap. The hard part will be what to do with the existing PATS system as well as the function of the cluster without swapping in the earlier clusters. Its all do-able it will just take some inginuity and time.
Old 06-04-2007, 08:56 PM   #11
that's awesome.. i had no idea it was that simple...
1991 lx coupe
Old 06-04-2007, 09:21 PM   #12
always asleepn
tulabeast's Avatar
just sell your car and go buy a v-8 shell much better
98 gt on the streets.
mod motors suk
Old 06-05-2007, 02:56 PM   #13
car is already paid off...and i already have built 5.0 with 347 stroker kit...and plus i want to be different theres no 99+ stangs here with a 5.0 in it...plus if something breaks..parts are hella lot cheaper than 4.6 mod motors...i know ive had a few
Old 06-05-2007, 05:11 PM   #14
not a hard swap.
If i was gonna swap a motor in a v6, it would be an ls1 anyways
94-95 je racing k member
if you have a manual, it is alread a t5 you just need to change the input shaft to work with the 5.0. I know a guy in a 3700 pound car going 11.7os on his HC 302 with one. he puls 1.5 60s.
slap a complete 8.8 rear in there as well and you can do the uppers and lowers ta the same time.
Old 06-06-2007, 03:02 PM   #15
what about wiring? i have the wiring harness.etc but do i HAVE to change my cluster, etc right away?
Old 06-06-2007, 03:17 PM   #16
i would go w/ aftermarket guages in a custom cluster.. just my .02 tho..
1991 lx coupe
