Old 03-07-2007, 11:03 PM   #1
fastcat1's Avatar
need help with a swap
I am restoring 2 65 coupes with a I6 and a 3spd but want to install a 289 or 302 with a auto. need help
1993 teal metalic cobra clone-----SOLD
1993 GMC Yukon 2 door 4x4
1965 coupe being built pics will be up soon
fastcat1 is offline   Reply With Quote
Old 03-08-2007, 06:53 AM   #2
Youll need to change the front springs and motor mounts. And ya may as well go to 5 lug while your at it. Also youll need to get the brake pedal for an auto and swap those out. The rest is pretty easy straight forward stuff since you have no electronics to worry about. Dont forget to get the kick down linkage for the auto trans from your donor vechile as well. Trans cross memeber should be OK you will need a different trans mount Not sure about D/S yoke Cant recall if the 2 trans have diff output shafts and youll have to check the lentgh. Also you may as well swap rearends as well so youll get 5 lug all around and the wimpy 6cyl rear wont last long with any real power. The early cars are pretty eay to swap and parts are readily available.
Pick up some Mustang mags there has been many an articale on this and alot of good tips to be found.
Old 03-08-2007, 04:52 PM   #3
fastcat1's Avatar
cool thanks for the info anybody else
Old 03-09-2007, 09:27 AM   #4
rpalaniz's Avatar
Parts
I have a complete drum to drum 7.5 5 lug axle, open Carrier..but ready to bolt on for 150.00 still in the car, adn you can use all the front end stuff of a Granada to make it 5 lug...also have a new tank, a set of Trim ring, magnum 500 wheels, And upholsterd front seats..let me know if you are intrested in any of that stuff..richard
rpalaniz is offline   Reply With Quote
Old 03-09-2007, 02:50 PM   #5
True and you get disc brakes in the deal.
Old 03-17-2007, 10:27 AM   #6
fastcat1's Avatar
well turn out that there is a 65 GT cut up and is a 5 lug so I am going to remove the front and rear set up and rebuild them and install them here are two pics. It's going to be a fun 2 yrs restoring them
Old 03-18-2007, 10:00 PM   #7
fastcat1's Avatar
found a 289 with trans that need to be rebuild
