Street Stylin' Stangs
need help with H.I.Ds
so im hooking up some H.I.Ds on my car and both are connected and put on correctly
but when i went to go turn them on they would not turn on anybody know why i need help
![]() 2000 LAZER RED SALEEN #0263 373s, 70MM throotle body ,port and polished intake, bassani x pipe, 3''magnaflow tips, mac cold air ,100 shot of nitrous 7'' keenwood flip out screen two 10'' JL audio subs with jensen amp |
nah there not cracked and .......yes there from xenoneyes
#4 | ||
¯\_(ò.Ó)_/¯
Hope you didn't get a bum set. I bought mine used and they work perfectly.
![]() Quote:
![]() Quote:
☆★sSs★☆
no im sure there not a bum set...bout 7or8 of us from triple-s have already bought the same set new and they've been all working fine
hmm...well if ya want come over to the house and i can help you install them, but not till like friday cause ima start packing cause i leave outa town tomorrow morning. I know when i installed them in cesars saleen we had a problem to but it ended up being in the harness frm where you connect to the aftermarkets |
maybe we can do it a fudds like wen we put yours on at The Track
no i didnt get a bum set i just dont know why they dont work
#8 | |
☆★sSs★☆
And just a fyi for you others..this was done out in a country road where no other cars were involved..were not that crazy |
#9 | |
yea that was some crazy shit fuck it lets do it
Use the foooorrrrcccceeee!!!
Check and make sure that the positive and negative wires are on the correct side... If I remember correctly the ballasts don't like the reverse polarity.
Turbos FTW...
yea i think thats the problem but wich is positive and wich is negative
Evil Angel
I had a bad ballast when I got mine from stangmods. Both worked at first, then one went out. One worked and one didn't. I thought it was a fluke, so I switched the ballast and the other bulb blew too. So I sent it all back and they sent me another set because it was warrantied, it just took like another month, and they sent me the wrong temp back, but I just kept em' and they've worked fine ever since. All the ballasts I've seen allow the harness to only be plugged one way, so I don't see how polarity could be wrong. Not sure about all of them though. Don't think this helps much, but that's my experience, so I would check the ballast connections and make sure they're plugged correctly.
#13 | |
It's LOUD but YOU looked!
if that is the case, 90% of the time it is a bad ground wire or your splice is loose. electrical is hard to diag wo seeing the car.
Chillin like a villian on penicillin
yeah i was gonna mention the harness thingy that was mentioned, usually the first thing that goes wrong with those
http://www.myspace.com/4652469 |
☆★sSs★☆
i think he's talking about his current stock lights...trust me when you put on those hid's..it feels like you just got a new set of seeing glasses
#17 |
yeah, but he says they are not working but dark right?
confused....
#18 |
i think its because the lights are really old
#19 |
6000k its white with a light blue tint
