Old 09-17-2004, 08:02 PM   #1
tdog's Avatar
need info!!
i have a problem. my mass air signal to the pcm is spiking really bad.The m/a is a brand new pro-m mas air.I have checked all the wires with a meter they are fine,what is the deal the car is bucking really bad because the signal is all over the place anyone have any input?
so many mods so little time.
tdog is offline   Reply With Quote
Old 11-02-2004, 02:06 PM   #2
tire's Avatar
go to a chain auto store and have them scan it. come back and tell us the code it throws. i remember an online code directory and i'm sure i can find it again if i know what i'm looking for.
not to insult your intelligence, but you have checked for a good seal, and the vac lines, right? what do you mean spiking on the pcm-maf line? Pro-M has had some probs but not what you are talking about if there is an elec. prob.
austin
Old 11-09-2004, 10:12 PM   #3
ccs
To truly diagnose that problem, a digital oscilloscope waveform is needed, referenced to rpm, on a long high gear run on the dyno. Are you seeing a spike , when you rev it, or what?
ccs is offline   Reply With Quote
