Old 03-31-2008, 12:17 PM   #1
texMUSTANGusmc's Avatar
Need input>> steel or alum.
im running a 2000 mustang gt. and as far as i understand is that 99 & 00 gt's come with a 8 bolt flywheel. im running 4.10's
well, should i get a steel or alum. flywheel.
thanks guys
texMUSTANGusmc is offline   Reply With Quote
Old 03-31-2008, 07:27 PM   #2
4.6stanger's Avatar
aluminum FTW!! Pricy but nice to have.
What will it be, Breakin 12's or Breakin drivetrain.
4.6stanger is online now   Reply With Quote
Old 03-31-2008, 10:43 PM   #3
LOL @ your mom
Trader Rating: (21)
Incorrect, you have a 6 bolt flywheel. If you have a Cobra or Mach, then you have an 8 bolt flywheel. All GT's came with just the 6 bolt cast iron crank, only forged cranks have an 8 bolt, unless it was from a Navigator (certain years).
An aluminum flywheel will make no difference with gears, but having 4.10's and an aluminum flywheel (basically, 1rst gear is useless). The less mass with get you in the upper RPM range in a hurry.
I have an 8 bolt in my engine, but I have a Cobra crank with a Fidanza flywheel.
The late 99 and 00-01 were Windsor engines, the rest were Romeo, maybe that is the confusion you have.
