Results 1 to 2 of 2
Thread: Nitrous Progressive controller
    Formerly 95 Blk Cobra Regular Member
    Mar 2007
    Corpus Christi
    Brand new in Box - Ready to go - I ordered this and then was given another unit...SAVE -
    Selling for $130 Shipped - FULL WARRANY AND Receipt.
    Its $157.11 shipped from Nitrous Outlet after tax and shipping
    Nitrous Outlet » Online Catalog » NItrous Outlet Digital Progressive Controller
    Nitrous Outlet Progressive controller with built in TPS activation and RPM safety switch.
    Nitrous Outlet's Progressive Contoller is an affordable, compact, and easy to use controller.
    Will easily fit into small spaces giving you more flexibility in install options.
    Hi amp continuous duty circuits.
    No computer needed!
    Adjust Start% and Build Time.
    Reset option for clutch cars.
    40 amp capable draw.
    RPM activation and RPM deactivation.
    TPS activation for falling signal, rising signals, low voltage signals, irregular signals and mechanical wide open throttle.
    Multi Gear lock Out Feature allows delaying the stage from activation.
    Can be used as a progressive controller only or use all controller features.
    Ground & Hot Output wires allow multiple accessory activations for use with timing retards, indication lights etc.
    Digital Hand Held Controller with LED read out for ease of programming and diagnosis, Conforms Vehicle RPM, Shows wide open throttle activation, shows gear lock out status, and shows activation status.
    Mar 2007
    Corpus Christi
    Sold Thanks LSS
