Old 07-22-2007, 06:04 PM   #1
strips in the face of danger
ramstang's Avatar
Send a message via AIM to ramstang Send a message via Yahoo to ramstang
no clutch
Allright I pulled the t5 out of my old car that my step brother bought from me cause the 1-2 shift was scratching. I put it back in today but now I have no clutch. everything bolted right up and is right other than i have no resistance on the clutch fork. Its on the pivot point in the right spot but its not hitting the clutch assy. at all. I'm at a major loss. I'm about ready to take trailer it to work.
ramstang is online now   Reply With Quote
Old 07-22-2007, 07:20 PM   #2
almost sound slike the throw otu bearing fell out at some point...
Old 07-23-2007, 08:12 AM   #3
Did you put the the T/O bearing on the fork??
DId the input shaft go thru the T/O or did you miss it?
Is the cable hooked to the fork?
Is it connected on the quadrant also?
Old 07-23-2007, 08:29 AM   #4
ramstang's Avatar
ya it was the throwout bearing. I dunno why i didn't think or see that. I finally called someone right after I posted this when they said that I wanted to kick my self.
Old 07-23-2007, 05:24 PM   #5
hehe it happens
Old 07-24-2007, 11:09 PM   #6
I eated it..
Trader Rating: (14)
Originally Posted by Ryan_65Stallion
lol. I love you to Jody
Old 07-25-2007, 05:01 PM   #7
ramstang's Avatar
