Old 10-21-2003, 10:17 PM   #1
noise from the tranny
Just recently the there has been this winding whistling(kinda hard to describe) noise that develops as Im driving. It only happens when the car is in gear, and it goes away as soon as I push in the clutch or let off the gas. The thing that really gets me is it only happens sporadically. I will be driving along and everything will be fine then the next stoplight the noise will start up as I go through the gears. There doesnt seem to be any power loss. Any ideas would be appreciated
92GT is offline   Reply With Quote
Old 10-21-2003, 11:13 PM   #2
THE OLD SCHOOL MODERATOR
1SLO85's Avatar
Maybe a throwout bearing?????????
1985 Mustang GT-Yeah, it's FAST
2006 Black on Black ProCharged Mustang GT-It's the Mrs'
2006 FX4 Superduty Powerstroke-The Toy Hauler
1SLO85 is offline   Reply With Quote
Old 10-22-2003, 02:51 PM   #3
That or the bearing retainer will wear out and make noises. Mine did that.
Old 10-22-2003, 03:18 PM   #4
how hard/easy is the bearing to get to and check?
Old 10-22-2003, 05:17 PM   #5
Used To Be Feetured
xtreme89gt's Avatar
Send a message via AIM to xtreme89gt
I have the same problem dude but mines an auto. It only does it in overdrive at low speeds like if i hold it at 1800 it will do the whining sound. But if i let off the gas it will stop. No clue what it is.
2003 Silver Cobra
For sale!
New motor(700 miles) and tranny/clutch(5000 miles).
All warranties for both, drives awesome, can sell stock or with mods to make 460rwhp and 501tq which= 11.70@119
pm for details.
Vid on old combo:
http://video.google.com/videoplay?do...80667909531212
xtreme89gt is offline   Reply With Quote
Old 10-22-2003, 05:46 PM   #6
i think it sounds like a bearing issue... but I have NO clue about tranny work.
Take it to the pro if you got the dough!!!
2002 White Mustang GT Coupe
aggiedj02 is offline   Reply With Quote
Old 10-22-2003, 06:47 PM   #7
You can take the cover off of the clutch fork and look around in there with a flashlight and may see something. But usually you will have to pull the tranny and just replace the TO bearing along with a steel retainer. First of all though make shure your clutch is adjusted properly.
Old 10-22-2003, 06:49 PM   #8
I dont know a whole lot about AOD's but it sounds like the front pump may be going out or acting up. I have a buddy that knows a lot about AOD's.
Old 11-03-2003, 08:18 AM   #9
Well I have to get part of my rearend opened up and looked at. The guy thinks it is some bearing that is is bad(no the TO). Fluid is also is seeping out from somewhere back there too. Overall I dont think its going to be a big deal(just having to replace some bearings and not the whole rear end) .So hopefully I will find out for sure this morning or afternoon. Thanks for your help though
Old 11-04-2003, 11:32 AM   #10
Well I am pissed. After further inspection, the whole rear end is shot. I had a pint of differential fluid put in a month ago the the guy left the plug where he put it while putting in the fluid so I was driving around without a plug. So atleast I dont have to pay the 1300 to have the rearend replaced. Then comes ANOTHER freakin problem that I didnt do anything to desreve. My cars previous owner had been using the wrong tranny fluid, instead of ATF he was using gear oil, I guess its to thick or something and it wore down the o-rings, then I figure since they got the tranny out might as well put in a new clutch, so about 2500 dollars later my car is gonna run about the same it did before:jeff: :jeff: :jeff:
Old 11-04-2003, 11:33 AM   #11
That sux man. Sorry to hear that. People are idiots.
