Results 1 to 16 of 16
Thread: O2 sensor delete
    Regular Regular Member ashleymarie's Avatar
    Jul 2010
    McKinney
    O2 sensor delete
    i have a couple questions, any and all info would be awesome. ok here it goes. i had BBK shorty headers and off road X-pipe installed on my car with cat delete. now im getting O2 sensor codes (check engine light) as i knew i would. i have heard of getting a O2 sensor delete kit to go with the upgrades that i have just had done and that it would take care of my problem. ok so heres the questions,
    1: what is this O2 sensor delete and how does it work.
    2: where can i get one, and how much is it. im in the McKinney area.
    3: once its installed will it allow my car to pass inspection.
    thanks in advance.
    MY FIRST GT!!!
    LSS Regular Regular Member
    Jan 2009
    san antonio
    1. don't know what an o2 sensor delete is. you need to have the rear o2's turned off in the tune
    2. see #1
    3. whether or not your car will pass inspection depends on if your area requires obdII testing. just turning the sensors off will not get the car to pass. you need a "emissions tune" that will get your car to pass even though the o2 sensor aren't working. not sure of anyone local that can do that, and i don't think too many tuners will advertise that they will do it either. you may have to put the stock h pipe on temporarily to pass if you're subject to obd testing. some folks say the spark plug anti-fouler trick will fool the pcm into thinking everything is in working order, but i've never tried it.
    also, when i had shorty headers i was getting codes for the front sensors also. so you need to pull the codes and see what you're actually getting.
    07gt, 4.56's, saleen udp's, hooker lt's, airaid cai, pro 50,1 piece aluminum drive shaft, bmr front safety loop, eibach pro kit, frpp hot rod cams, adj lca's, msd launch master [email protected]
    http://www.lonestarstangs.com/forum/image.php?type=sigpic&userid=5085&dateline=1231901  214
    LoneStarStangs Addict Regular Member VMT's Avatar
    Nov 2007
    San Antonio
    I believe you talking about a set of mils(malfunction indication light)as far as your cat delete goes.They go between the 02 sensors and the factory harness and plug right in.BBK makes a them and a set will run you about $50.00 plus shipping.You can get them on line,google BBK mils and you'll find them.They basically "trick" the computer by sending a signal that the cats are still on the car.I put them in them when I installed my long tubes and o/r X,no problems.They are only for the rear sensors.As far as inspection goes,like Blu Ovl said,if you dont have the emissions testing in your area you might find a shop that might pass you if they don't look under your car.Ask other Mustang owners where they take their cars,they can probably help you w/ that.Hope this helped.
    Nov 2007
    San Antonio
    Sorry,my proof reading is good not!
    Jul 2010
    McKinney
    THANKS for the info guys. i just went autozone and had them pull the codes that my car is giving off. here they are.
    1: P0506 - Idle Air Control System RPM Lower Than Expected
    2: P0161 - Oxygen O2 Sensor Circuit Low Voltage (Bank 2, Sensor 2)
    3: P2272 - O2 Sensor Signal Stuck Lean
    MY FIRST GT!!!
  6. #6
    Oct 2006
    Denton
    i think a good tune with something like an xcal will take care of it... if you buy one from sct, they will usually work with you on it... i'll have to look into it, but i may be able to flash a factory tune onto your car with o2's turned off... you can still pass inspection but it will take a while for enough monitors to clear to pass... i'm an inspector in denton..
  7. #7
    Jul 2010
    McKinney
    ok thats works im in McKinney thats not to bad of a drive.
    MY FIRST GT!!!
  8. #8
    Jan 2009
    san antonio
    i haven't experienced this myself, but i'm told the mil eliminators are inconsistent on 05+ cars. sometimes they work, sometimes not.
    do you guys to obd testing there? we don't have it in san antonio and i've never had a problem getting the car to pass with no cats and the rear o2's turned off. i'm not sure what i'll do if we ever start obd testing here
  9. #9
    Oct 2006
    Denton
    yes, obd testing for 96+ and dyno sniffer testing for 95-86
  10. #10
    Nov 2007
    San Antonio
    Thanks for the input on mils for the '05 and up.I thought about that after my post,I've never run across anyone who has put mils on a '05 and up to cover the o/r pipe.Interesting,a little research is in order,thanks Blu Ovl.
  11. #11
    Jan 2009
    san antonio
    i would like to try the anti fouler trick for grins just to see if it works
  12. #12
    Jul 2010
    McKinney
    well for now i have had the cats and H pipe put back on till i can get the money together for a tuner and the mils. dont sound the same now.
    MY FIRST GT!!!
  13. #13
    FAIL
    Sep 2010
    Missouri
    Having an oxygen sensor delete can be a little bit tricky, but try to really check if things would really be efficient if you do that. From my experience, it can be very much costful on stuffs on your car. I'm not sure if that's the case.
  14. #14
    Dec 2003
    SanAntonio
    You cannot totally delete the o2 sensors. your car will not run with out the frt 2 as they tell the computer how much fuel to allow the injectors to squirt based on the efficiency of the burn taking place. You can turn off the rears as stated or run mils if available for your car.
    85GT FACH1 FINISHED
  15. #15
    Hi-Po Po-Po Regular Member WarHorse's Avatar
    Feb 2010
    NE San Antonio
    Quote Originally Posted by ashleymarie View Post
    thanks in advance.
    I can answer #3 for you...with no cats on your car, it's definitely illegal. But...that won't stop some shops out there from giving you an inspection sticker.
  16. #16
    Regular Regular Member ChaseO!'s Avatar
    Dec 2009
    Webster TX
    Quote Originally Posted by WarHorse View Post
    07 GT.
    JLT cold air intake
    Pypes off road X pipe
    SLP Loudmouths
    Pypes axle back race pipes
    Custom tuned by brenspeed
    Comp stage 2 thumper cams
    3.90 gear
    Ram clutch
    BOTTLE FED!
