Old 01-23-2006, 08:20 PM   #1
RIP Cledus Snow
OBD-2 Diagnostic codes
P0100- Mass or Volume Air Flow Circuit Malfunction
P0101- Mass or Volume Air Flow Circuit Range/Performance Problem
P0121- In-Range Operating Throttle Position Sensor circuit failure.
P0122- Throttle Position Sensor circuit Low Input.
P0123- Throttle Position Sensor circuit High Input.
P0125- Insufficient Coolant Temperature to enter Closed Loop.
P0126- Insufficient Coolant Temperature for Stable Operation.
P0102- Mass or Volume Air Flow Circuit Low Input
P0103- Mass or Volume Air Flow Circuit High Input
P0104- Mass or Volume Air Flow Circuit Intermittent
P0105- Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106- Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107- Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108- Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109- Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110- Intake Air Temperature Circuit Malfunction
P0111- Intake Air Temperature Circuit Range/Performance Problem
P0112- Intake Air Temperature Circuit Low Input
P0113- Intake Air Temperature Circuit High Input
P0114- Intake Air Temperature Circuit Intermittent
P0115- Engine Coolant Temperature Circuit Malfunction
P0116- Engine Coolant Temperature Circuit Range/Performance Problem
P0117- Engine Coolant Temperature Circuit Low Input
P0118- Engine Coolant Temperature Circuit High Input
P0119- Engine Coolant Temperature Circuit Intermittent
P0120- Throttle/Petal Position Sensor/Switch A Circuit Malfunction
P0121- Throttle/Petal Position Sensor/Switch A Circuit Range/Performance Problem
P0122- Throttle/Petal Position Sensor/Switch A Circuit Low Input
P0123- Throttle/Petal Position Sensor/Switch A Circuit High Input
P0124- Throttle/Petal Position Sensor/Switch A Circuit Intermittent
P0125- Insufficient Coolant Temperature for Closed Loop Fuel Control
P0130- O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0131- O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132- O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133- O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134- O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135- O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136- O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137- O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138- O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139- O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140- O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141- O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142- O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0143- O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
P0144- O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
P0145- O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146- O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
P0147- O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0150- O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0151- O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152- O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153- O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154- O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155- O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156- O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157- O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158- O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159- O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160- O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161- O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162- O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163- O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164- O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165- O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166- O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167- O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0170- Fuel Trim Malfunction (Bank 1)
P0171- System too Lean (Bank 1)
P0172- System too Rich (Bank 1)
P0173- Fuel Trim Malfunction (Bank 2)
P0174- System too Lean (Bank 2)
P0175- System too Rich (Bank 2)
P0176- Fuel Composition Sensor Circuit Malfunction
P0177- Fuel Composition Sensor Circuit Range/Performance
P0178- Fuel Composition Sensor Circuit Low Input
P0179- Fuel Composition Sensor Circuit High Input
P0180- Fuel Temperature Sensor A Circuit Malfunction
P0181- Fuel Temperature Sensor A Circuit Range/Performance
P0182- Fuel Temperature Sensor A Circuit Low Input
P0183- Fuel Temperature Sensor A Circuit High Input
P0184- Fuel Temperature Sensor A Circuit Intermittent
P0185- Fuel Temperature Sensor B Circuit Malfunction
P0186- Fuel Temperature Sensor B Circuit Range/Performance
P0187- Fuel Temperature Sensor B Circuit Low Input
P0188- Fuel Temperature Sensor B Circuit High Input
P0189- Fuel Temperature Sensor B Circuit Intermittent
P0190- Fuel Rail Pressure Sensor Circuit Malfunction
P0191- Fuel Rail Pressure Sensor Circuit Range/Performance
P0192- Fuel Rail Pressure Sensor Circuit Low Input
P0193- Fuel Rail Pressure Sensor Circuit High Input
P0194- Fuel Rail Pressure Sensor Circuit Intermittent
P0195- Engine Oil Temperature Sensor Malfunction
P0196- Engine Oil Temperature Sensor Range/Performance
P0197- Engine Oil Temperature Sensor Low
P0198- Engine Oil Temperature Sensor High
P0199- Engine Oil Temperature Sensor Intermittent
P0200- Injector Circuit Malfunction
P0201- Injector Circuit Malfunction - Cylinder 1
P0202- Injector Circuit Malfunction - Cylinder 2
P0203- Injector Circuit Malfunction - Cylinder 3
P0204- Injector Circuit Malfunction - Cylinder 4
P0205- Injector Circuit Malfunction - Cylinder 5
P0206- Injector Circuit Malfunction - Cylinder 6
P0207- Injector Circuit Malfunction - Cylinder 7
P0208- Injector Circuit Malfunction - Cylinder 8
P0209- Injector Circuit Malfunction - Cylinder 9
P0210- Injector Circuit Malfunction - Cylinder 10
P0211- Injector Circuit Malfunction - Cylinder 11
P0212- Injector Circuit Malfunction - Cylinder 12
P0213- Cold Start Injector 1 Malfunction
P0214- Cold Start Injector 2 Malfunction
P0215- Engine Shutoff Solenoid Malfunction
P0216- Injection Timing Control Circuit Malfunction
P0217- Engine Overtemp Condition
P0218- Transmission Over Temperature Condition
P0219- Engine Overspeed Condition
P0220- Throttle/Petal Position Sensor/Switch B Circuit Malfunction
P0221- Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
P0222- Throttle/Petal Position Sensor/Switch B Circuit Low Input
P0223- Throttle/Petal Position Sensor/Switch B Circuit High Input
P0224- Throttle/Petal Position Sensor/Switch B Circuit Intermittent
P0225- Throttle/Petal Position Sensor/Switch C Circuit Malfunction
P0226- Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
P0227- Throttle/Petal Position Sensor/Switch C Circuit Low Input
P0228- Throttle/Petal Position Sensor/Switch C Circuit High Input
P0229- Throttle/Petal Position Sensor/Switch C Circuit Intermittent
P0230- Fuel Pump Primary Circuit Malfunction
P0231- Fuel Pump Secondary Circuit Low
P0232- Fuel Pump Secondary Circuit High
P0233- Fuel Pump Secondary Circuit Intermittent
P0234- Engine Overboost Condition
P0235- Turbocharger Boost Sensor A Circuit Malfunction
P0236- Turbocharger Boost Sensor A Circuit Range/Performance
P0237- Turbocharger Boost Sensor A Circuit Low
P0238- Turbocharger Boost Sensor A Circuit High
P0239- Turbocharger Boost Sensor B Malfunction
P0240- Turbocharger Boost Sensor B Circuit Range/Performance
P0241- Turbocharger Boost Sensor B Circuit Low
P0242- Turbocharger Boost Sensor B Circuit High
P0243- Turbocharger Wastegate Solenoid A Malfunction
P0244- Turbocharger Wastegate Solenoid A Range/Performance
P0245- Turbocharger Wastegate Solenoid A Low
P0246- Turbocharger Wastegate Solenoid A High
P0247- Turbocharger Wastegate Solenoid B Malfunction
P0248- Turbocharger Wastegate Solenoid B Range/Performance
P0249- Turbocharger Wastegate Solenoid B Low
P0250- Turbocharger Wastegate Solenoid B High
P0251- Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
P0252- Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0253- Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254- Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255- Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256- Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
P0257- Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
P0258- Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
P0259- Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
P0260- Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
Old 01-23-2006, 08:22 PM   #2
RIP Cledus Snow
P0261- Cylinder 1 Injector Circuit Low
P0262- Cylinder 1 Injector Circuit High
P0263- Cylinder 1 Contribution/Balance Fault
P0264- Cylinder 2 Injector Circuit Low
P0265- Cylinder 2 Injector Circuit High
P0266- Cylinder 2 Contribution/Balance Fault
P0267- Cylinder 3 Injector Circuit Low
P0268- Cylinder 3 Injector Circuit High
P0269- Cylinder 3 Contribution/Balance Fault
P0270- Cylinder 4 Injector Circuit Low
P0271- Cylinder 4 Injector Circuit High
P0272- Cylinder 4 Contribution/Balance Fault
P0273- Cylinder 5 Injector Circuit Low
P0274- Cylinder 5 Injector Circuit High
P0275- Cylinder 5 Contribution/Balance Fault
P0276- Cylinder 6 Injector Circuit Low
P0277- Cylinder 6 Injector Circuit High
P0278- Cylinder 6 Contribution/Balance Fault
P0279- Cylinder 7 Injector Circuit Low
P0280- Cylinder 7 Injector Circuit High
P0281- Cylinder 7 Contribution/Balance Fault
P0282- Cylinder 8 Injector Circuit Low
P0283- Cylinder 8 Injector Circuit High
P0284- Cylinder 8 Contribution/Balance Fault
P0285- Cylinder 9 Injector Circuit Low
P0286- Cylinder 9 Injector Circuit High
P0287- Cylinder 9 Contribution/Balance Fault
P0288- Cylinder 10 Injector Circuit Low
P0289- Cylinder 10 Injector Circuit High
P0290- Cylinder 10 Contribution/Balance Fault
P0291- Cylinder 11 Injector Circuit Low
P0292- Cylinder 11 Injector Circuit High
P0293- Cylinder 11 Contribution/Balance Fault
P0294- Cylinder 12 Injector Circuit Low
P0295- Cylinder 12 Injector Circuit High
P0296- Cylinder 12 Contribution/Range Fault
P0300- Random/Multiple Cylinder Misfire Detected
P0301- Cylinder 1 Misfire Detected
P0302- Cylinder 2 Misfire Detected
P0303- Cylinder 3 Misfire Detected
P0304- Cylinder 4 Misfire Detected
P0305- Cylinder 5 Misfire Detected
P0306- Cylinder 6 Misfire Detected
P0307- Cylinder 7 Misfire Detected
P0308- Cylinder 8 Misfire Detected
P0309- Cylinder 9 Misfire Detected
P0311- Cylinder 11 Misfire Detected
P0312- Cylinder 12 Misfire Detected
P0320- Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321- Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322- Ignition/Distributor Engine Speed Input Circuit No Signal
P0323- Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325- Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
P0326- Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327- Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328- Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329- Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
P0330- Knock Sensor 2 Circuit Malfunction (Bank 2)
P0331- Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332- Knock Sensor 2 Circuit Low Input (Bank 2)
P0333- Knock Sensor 2 Circuit High Input (Bank 2)
P0334- Knock Sensor 2 Circuit Intermittent (Bank 2)
P0335- Crankshaft Position Sensor A Circuit Malfunction
P0336- Crankshaft Position Sensor A Circuit Range/Performance
P0337- Crankshaft Position Sensor A Circuit Low Input
P0338- Crankshaft Position Sensor A Circuit High Input
P0339- Crankshaft Position Sensor A Circuit Intermittent
P0340- Camshaft Position Sensor Circuit Malfunction
P0341- Camshaft Position Sensor Circuit Range/Performance
P0342- Camshaft Position Sensor Circuit Low Input
P0343- Camshaft Position Sensor Circuit High Input
P0344- Camshaft Position Sensor Circuit Intermittent
P0350- Ignition Coil Primary/Secondary Circuit Malfunction
P0351- Ignition Coil A Primary/Secondary Circuit Malfunction
P0352- Ignition Coil B Primary/Secondary Circuit Malfunction
P0353- Ignition Coil C Primary/Secondary Circuit Malfunction
P0354- Ignition Coil D Primary/Secondary Circuit Malfunction
P0355- Ignition Coil E Primary/Secondary Circuit Malfunction
P0356- Ignition Coil F Primary/Secondary Circuit Malfunction
P0357- Ignition Coil G Primary/Secondary Circuit Malfunction
P0358- Ignition Coil H Primary/Secondary Circuit Malfunction
P0359- Ignition Coil I Primary/Secondary Circuit Malfunction
P0360- Ignition Coil J Primary/Secondary Circuit Malfunction
P0361- Ignition Coil K Primary/Secondary Circuit Malfunction
P0362- Ignition Coil L Primary/Secondary Circuit Malfunction
P0370- Timing Reference High Resolution Signal A Malfunction
P0371- Timing Reference High Resolution Signal A Too Many Pulses
P0372- Timing Reference High Resolution Signal A Too Few Pulses
P0373- Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
P0374- Timing Reference High Resolution Signal A No Pulses
P0375- Timing Reference High Resolution Signal B Malfunction
P0376- Timing Reference High Resolution Signal B Too Many Pulses
P0377- Timing Reference High Resolution Signal B Too Few Pulses
P0378- Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
P0379- Timing Reference High Resolution Signal B No Pulses
P0380- Glow Plug/Heater Circuit "A" Malfunction
P0381- Glow Plug/Heater Indicator Circuit Malfunction
P0382- Glow Plug/Heater Circuit "B" Malfunction
P0385- Crankshaft Position Sensor B Circuit Malfunction
P0386- Crankshaft Position Sensor B Circuit Range/Performance
P0387- Crankshaft Position Sensor B Circuit Low Input
P0388- Crankshaft Position Sensor B Circuit High Input
P0389- Crankshaft Position Sensor B Circuit Intermittent
P0400- Exhaust Gas Recirculation Flow Malfunction
P0401- Exhaust Gas Recirculation Flow Insufficient Detected
P0402- Exhaust Gas Recirculation Flow Excessive Detected
P0403- Exhaust Gas Recirculation Circuit Malfunction
P0404- Exhaust Gas Recirculation Circuit Range/Performance
P0405- Exhaust Gas Recirculation Sensor A Circuit Low
P0406- Exhaust Gas Recirculation Sensor A Circuit High
P0407- Exhaust Gas Recirculation Sensor B Circuit Low
P0408- Exhaust Gas Recirculation Sensor B Circuit High
P0410- Secondary Air Injection System Malfunction
P0411- Secondary Air Injection System Incorrect Flow Detected
P0412- Secondary Air Injection System Switching Valve A Circuit Malfunction
P0413- Secondary Air Injection System Switching Valve A Circuit Open
P0414- Secondary Air Injection System Switching Valve A Circuit Shorted
P0415- Secondary Air Injection System Switching Valve B Circuit Malfunction
P0416- Secondary Air Injection System Switching Valve B Circuit Open
P0417- Secondary Air Injection System Switching Valve B Circuit Shorted
P0418- Secondary Air Injection System Relay "A" Circuit Malfunction
P0419- Secondary Air Injection System Relay "B" Circuit Malfunction
P0420- Catalyst System Efficiency Below Threshold (Bank 1)
P0421- Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422- Main Catalyst Efficiency Below Threshold (Bank 1)
P0423- Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424- Heated Catalyst Temperature Below Threshold (Bank 1)
P0430- Catalyst System Efficiency Below Threshold (Bank 2)
P0431- Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432- Main Catalyst Efficiency Below Threshold (Bank 2)
P0433- Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434- Heated Catalyst Temperature Below Threshold (Bank 2)
P0440- Evaporative Emission Control System Malfunction
P0441- Evaporative Emission Control System Incorrect Purge Flow
P0442- Evaporative Emission Control System Leak Detected (small leak)
P0443- Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444- Evaporative Emission Control System Purge Control Valve Circuit Open
P0445- Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446- Evaporative Emission Control System Vent Control Circuit Malfunction
P0447- Evaporative Emission Control System Vent Control Circuit Open
P0448- Evaporative Emission Control System Vent Control Circuit Shorted
P0449- Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450- Evaporative Emission Control System Pressure Sensor Malfunction
P0451- Evaporative Emission Control System Pressure Sensor Range/Performance
P0452- Evaporative Emission Control System Pressure Sensor Low Input
P0453- Evaporative Emission Control System Pressure Sensor High Input
P0454- Evaporative Emission Control System Pressure Sensor Intermittent
P0455- Evaporative Emission Control System Leak Detected (gross leak)
P0460- Fuel Level Sensor Circuit Malfunction
P0461- Fuel Level Sensor Circuit Range/Performance
P0462- Fuel Level Sensor Circuit Low Input
P0463- Fuel Level Sensor Circuit High Input
P0464- Fuel Level Sensor Circuit Intermittent
P0465- Purge Flow Sensor Circuit Malfunction
P0466- Purge Flow Sensor Circuit Range/Performance
P0467- Purge Flow Sensor Circuit Low Input
P0468- Purge Flow Sensor Circuit High Input
P0469- Purge Flow Sensor Circuit Intermittent
P0470- Exhaust Pressure Sensor Malfunction
P0471- Exhaust Pressure Sensor Range/Performance
P0472- Exhaust Pressure Sensor Low
P0473- Exhaust Pressure Sensor High
P0474- Exhaust Pressure Sensor Intermittent
P0475- Exhaust Pressure Control Valve Malfunction
P0476- Exhaust Pressure Control Valve Range/Performance
P0477- Exhaust Pressure Control Valve Low
P0478- Exhaust Pressure Control Valve High
P0479- Exhaust Pressure Control Valve Intermittent
P0480- Cooling Fan 1 Control Circuit Malfunction
P0481- Cooling Fan 2 Control Circuit Malfunction
P0482- Cooling Fan 3 Control Circuit Malfunction
P0483- Cooling Fan Rationality Check Malfunction
P0484- Cooling Fan Circuit Over Current
P0485- Cooling Fan Power/Ground Circuit Malfunction
P0500- Vehicle Speed Sensor Malfunction
P0501- Vehicle Speed Sensor Range/Performance
P0502- Vehicle Speed Sensor Low Input
P0503- Vehicle Speed Sensor Intermittent/Erratic/High
P0505- Idle Control System Malfunction
P0506- Idle Control System RPM Lower Than Expected
P0507- Idle Control System RPM Higher Than Expected
P0510- Closed Throttle Position Switch Malfunction
P0520- Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521- Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522- Engine Oil Pressure Sensor/Switch Circuit Low Voltage
P0523- Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0530- A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531- A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532- A/C Refrigerant Pressure Sensor Circuit Low Input
P0533- A/C Refrigerant Pressure Sensor Circuit High Input
P0534- Air Conditioner Refrigerant Charge Loss
P0550- Power Steering Pressure Sensor Circuit Malfunction
P0551- Power Steering Pressure Sensor Circuit Range/Performance
P0552- Power Steering Pressure Sensor Circuit Low Input
P0553- Power Steering Pressure Sensor Circuit High Input
P0554- Power Steering Pressure Sensor Circuit Intermittent
P0560- System Voltage Malfunction
P0561- System Voltage Unstable
P0562- System Voltage Low
P0563- System Voltage High
P0565- Cruise Control On Signal Malfunction
P0566- Cruise Control Off Signal Malfunction
P0567- Cruise Control Resume Signal Malfunction
P0568- Cruise Control Set Signal Malfunction
P0569- Cruise Control Coast Signal Malfunction
P0570- Cruise Control Accel Signal Malfunction
P0571- Cruise Control/Brake Switch A Circuit Malfunction
P0572- Cruise Control/Brake Switch A Circuit Low
P0573- Cruise Control/Brake Switch A Circuit High
P0574- Cruise Control Related Malfunction
P0575- Cruise Control Related Malfunction
P0576- Cruise Control Related Malfunction
P0577- Cruise Control Related Malfunction
P0578- Cruise Control Related Malfunction
P0579- Cruise Control Related Malfunction
P0580- Cruise Control Related Malfunction
P0600- Serial Communication Link Malfunction
P0601- Internal Control Module Memory Check Sum Error
P0602- Control Module Programming Error
P0603- Internal Control Module Keep Alive Memory (KAM) Error
P0604- Internal Control Module Random Access Memory (RAM) Error
P0605- Internal Control Module Read Only Memory (ROM) Error
P0606- PCM Processor Fault
P0608- Control Module VSS Output "A" Malfunction
P0609- Control Module VSS Output "B" Malfunction
P0620- Generator Control Circuit Malfunction
P0621- Generator Lamp "L" Control Circuit Malfunction
P0622- Generator Field "F" Control Circuit Malfunction
P0650- Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0654- Engine RPM Output Circuit Malfunction
P0655- Engine Hot Lamp Output Control Circuit Malfucntion
P0656- Fuel Level Output Circuit Malfunction
P0700- Transmission Control System Malfunction
P0701- Transmission Control System Range/Performance
P0702- Transmission Control System Electrical
P0703- Torque Converter/Brake Switch B Circuit Malfunction
P0704- Clutch Switch Input Circuit Malfunction
P0705- Transmission Range Sensor Circuit malfunction (PRNDL Input)
P0706- Transmission Range Sensor Circuit Range/Performance
P0707- Transmission Range Sensor Circuit Low Input
P0708- Transmission Range Sensor Circuit High Input
P0709- Transmission Range Sensor Circuit Intermittent
P0710- Transmission Fluid Temperature Sensor Circuit Malfunction
P0711- Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712- Transmission Fluid Temperature Sensor Circuit Low Input
P0713- Transmission Fluid Temperature Sensor Circuit High Input
P0714- Transmission Fluid Temperature Sensor Circuit Intermittent
P0715- Input/Turbine Speed Sensor Circuit Malfunction
P0716- Input/Turbine Speed Sensor Circuit Range/Performance
P0717- Input/Turbine Speed Sensor Circuit No Signal
P0718- Input/Turbine Speed Sensor Circuit Intermittent
P0719- Torque Converter/Brake Switch B Circuit Low
P0720- Output Speed Sensor Circuit Malfunction
P0721- Output Speed Sensor Range/Performance
P0722- Output Speed Sensor No Signal
P0723- Output Speed Sensor Intermittent
P0724- Torque Converter/Brake Switch B Circuit High
P0725- Engine Speed input Circuit Malfunction
P0726- Engine Speed Input Circuit Range/Performance
P0727- Engine Speed Input Circuit No Signal
P0728- Engine Speed Input Circuit Intermittent
Old 01-23-2006, 08:23 PM   #3
RIP Cledus Snow
P0730- Incorrect Gear Ratio
P0731- Gear 1 Incorrect ratio
P0732- Gear 2 Incorrect ratio
P0733- Gear 3 Incorrect ratio
P0734- Gear 4 Incorrect ratio
P0735- Gear 5 Incorrect ratio
P0736- Reverse incorrect gear ratio
P0740- Torque Converter Clutch Circuit Malfuction
P0741- Torque Converter Clutch Circuit Performance or Stuck Off
P0742- Torque Converter Clutch Circuit Stuck On
P0743- Torque Converter Clutch Circuit Electrical
P0744- Torque Converter Clutch Circuit Intermittent
P0745- Pressure Control Solenoid Malfunction
P0746- Pressure Control Solenoid Performance or Stuck Off
P0747- Pressure Control Solenoid Stuck On
P0748- Pressure Control Solenoid Electrical
P0749- Pressure Control Solenoid Intermittent
P0750- Shift Solenoid A Malfunction
P0751- Shift Solenoid A Performance or Stuck Off
P0752- Shift Solenoid A Stuck On
P0753- Shift Solenoid A Electrical
P0754- Shift Solenoid A Intermittent
P0755- Shift Solenoid B Malfunction
P0756- Shift Solenoid B Performance or Stuck Off
P0757- Shift Solenoid B Stuck On
P0758- Shift Solenoid B Electrical
P0759- Shift Solenoid B Intermittent
P0760- Shift Solenoid C Malfunction
P0761- Shift Solenoid C Performance or Stuck Off
P0762- Shift Solenoid C Stuck On
P0763- Shift Solenoid C Electrical
P0764- Shift Solenoid C Intermittent
P0765- Shift Solenoid D Malfunction
P0766- Shift Solenoid D Performance or Stuck Off
P0767- Shift Solenoid D Stuck On
P0768- Shift Solenoid D Electrical
P0769- Shift Solenoid D Intermittent
P0770- Shift Solenoid E Malfunction
P0771- Shift Solenoid E Performance or Stuck Off
P0772- Shift Solenoid E Stuck On
P0773- Shift Solenoid E Electrical
P0774- Shift Solenoid E Intermittent
P0780- Shift Malfunction
P0781- 1-2 Shift Malfunction
P0782- 2-3 Shift Malfunction
P0783- 3-4 Shift Malfunction
P0784- 4-5 Shift Malfunction
P0785- Shift/Timing Solenoid Malfunction
P0786- Shift/Timing Solenoid Range/Performance
P0787- Shift/Timing Solenoid Low
P0788- Shift/Timing Solenoid High
P0789- Shift/Timing Solenoid Intermittent
P0790- Normal/Performance Switch Circuit Malfunction
P0801- Reverse Inhibit Control Circuit Malfunction
P0803- 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0804- 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
P1106- Manifold Absolute Pressure (MAP) sensor circuit intermittent high voltage
P1107- Manifold Absolute Pressure (MAP) sensor circuit intermittent low voltage
P1108- BARO to MAP signal circuit comparison too high
P1111- Intake Air Temperature (IAT) sensor intermittent high voltage
P1112- Intake Air Temperature (IAT) sensor intermittent low voltage
P1114- Engine Coolant Temperature (ECT) sensor circuit intermittent low voltage
P1115- Engine Coolant Temperature (ECT) sensor circuit intermittent high voltage
P1121- Throttle Position (TP) sensor inconsistent with MAF Sensor high voltage
P1122- Throttle Position (TP) sensor inconsistent with MAF Sensor low voltage
P1133- Heated Oxygen Sensor (HO2S) insufficient switching bank 1 sensor 1 (Rear Bank)
P1134- Heated Oxygen Sensor (HO2S) transition time ratio bank 1 sensor 1 (Rear Bank)
P1153- Heated Oxygen Sensor (HO2S) insufficient switching bank 2 sensor 1 (Front Bank)
P1154- Heated Oxygen Sensor (HO2S) transition time ratio bank 2 sensor 1 (Front Bank)
P1189- Engine Oil Pressure Switch Circuit
P1258- Engine Metal Over Temperature Protection
P1320- Ignition Control (IC) Module 4x Reference Circuit Intermittent No Pulses
P1323- Ignition Control (IC) Module 24x Reference Circuit low frequency
P1350- Ignition Control System
P1370- Ignition Control (IC) Module 4x Reference too many pulses
P1371- Ignition Control (IC) Module 4x Reference too few pulses
P1375- Ignition Control (IC) Module 24x Reference High Voltage
P1376- Ignition Ground Circuit
P1377- Ignition Control (IC) Module Cam Pulse to 4x Reference Pulse Comparison
P1380- EBTCM DTC Detected-Rough Data Unusable
P1381- Misfire Detected-No EBTCM/PCM Serial Data
P1404- Exhaust Gas Recirculation (EGR) Valve Pintle Stuck Open
P1441- Evaporative System Flow During Non-Purge
P1483- Engine Cooling System Performance
P1508- Idle Air Control (IAC) System -Low RPM
P1520- Intake Manifold Runner Control (IMRC) circuit malfunction
P1524- Throttle Position (TP) Sensor Learned Closed Throttle Angle Degrees Out-Of-Range
P1527- Trans Range / Pressure Switch Comparison
P1554- Cruise Engaged Circuit High Voltage
P1560- Cruise Control System-Transaxle Not in Drive
P1564- Cruise Control System-Vehicle Acceleration too high
P1566- Cruise Control System-Engine RPM Too High
P1567- Cruise Control- ABCS Active
P1570- Cruise Control System - Traction Control Active
P1571- Traction Control System PWM Circuit No Frequency
P1574- EBTCM System- Stop Lamp Switch Circuit High Voltage
P1575- Extended Travel Brake Switch Circuit High Voltage
P1579- Park/Neutral to Drive/Reverse At high Throttle Angle
P1599- Engine Stall or Near Stall Detected
P1602- Loss of EBTCM Serial Data
P1603- Loss of SDM Serial Data
P1604- Loss of IPC Serial Data
P1605- Loss of HVACC Serial Data
P1610- Loss of PZM Serial Data
P1611- Loss of CVRTD Serial Data
P1617- Engine Oil Level Switch Circuit
P1621- PCM Memory Performance
P1626- Theft Deterrent System - Fuel Enable Circuit
P1630- Theft Deterrent - PCM in Learn Mode
P1631- Theft Deterrent - Password Incorrect
P1632- Theft Deterrent - Fuel Disabled
P1633- Ignition Supplement Power Circuit Low Voltage
P1634- Ignition 1 Power Circuit Low Voltage
P1640- Driver 1 - Input High Voltage
P1641- Malfunction Indicator Lamp (MIL) Control Circuit
P1642- Vehicle Speed Output Circuit
P1644- Delivered Torque Output Circuit
P1645- EVAP Solenoid Output Circuit
P1646- EVAP Vent Valve Output Circuit
P1650- Driver 2 - Input High Voltage
P1652- Lift/Dive Circuit
P1654- Cruise Disable Output Circuit
P1660- Cooling Fan Control Circuits
