Check ya later!
OBD-2 Diagnostic codes
P0100- Mass or Volume Air Flow Circuit Malfunction
P0101- Mass or Volume Air Flow Circuit Range/Performance Problem P0121- In-Range Operating Throttle Position Sensor circuit failure. P0122- Throttle Position Sensor circuit Low Input. P0123- Throttle Position Sensor circuit High Input. P0125- Insufficient Coolant Temperature to enter Closed Loop. P0126- Insufficient Coolant Temperature for Stable Operation. P0102- Mass or Volume Air Flow Circuit Low Input P0103- Mass or Volume Air Flow Circuit High Input P0104- Mass or Volume Air Flow Circuit Intermittent P0105- Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction P0106- Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem P0107- Manifold Absolute Pressure/Barometric Pressure Circuit Low Input P0108- Manifold Absolute Pressure/Barometric Pressure Circuit High Input P0109- Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent P0110- Intake Air Temperature Circuit Malfunction P0111- Intake Air Temperature Circuit Range/Performance Problem P0112- Intake Air Temperature Circuit Low Input P0113- Intake Air Temperature Circuit High Input P0114- Intake Air Temperature Circuit Intermittent P0115- Engine Coolant Temperature Circuit Malfunction P0116- Engine Coolant Temperature Circuit Range/Performance Problem P0117- Engine Coolant Temperature Circuit Low Input P0118- Engine Coolant Temperature Circuit High Input P0119- Engine Coolant Temperature Circuit Intermittent P0120- Throttle/Petal Position Sensor/Switch A Circuit Malfunction P0121- Throttle/Petal Position Sensor/Switch A Circuit Range/Performance Problem P0122- Throttle/Petal Position Sensor/Switch A Circuit Low Input P0123- Throttle/Petal Position Sensor/Switch A Circuit High Input P0124- Throttle/Petal Position Sensor/Switch A Circuit Intermittent P0125- Insufficient Coolant Temperature for Closed Loop Fuel Control P0126- Insufficient Coolant Temperature for Stable Operation P0130- O2 Sensor Circuit Malfunction (Bank 1 Sensor 1) P0131- O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1) P0132- O2 Sensor Circuit High Voltage (Bank 1 Sensor 1) P0133- O2 Sensor Circuit Slow Response (Bank 1 Sensor 1) P0134- O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1) P0135- O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) P0136- O2 Sensor Circuit Malfunction (Bank 1 Sensor 2) P0137- O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2) P0138- O2 Sensor Circuit High Voltage (Bank 1 Sensor 2) P0139- O2 Sensor Circuit Slow Response (Bank 1 Sensor 2) P0140- O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2) P0141- O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2) P0142- O2 Sensor Circuit Malfunction (Bank 1 Sensor 3) P0143- O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3) P0144- O2 Sensor Circuit High Voltage (Bank 1 Sensor 3) P0145- O2 Sensor Circuit Slow Response (Bank 1 Sensor 3) P0146- O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3) P0147- O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3) P0150- O2 Sensor Circuit Malfunction (Bank 2 Sensor 1) P0151- O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1) P0152- O2 Sensor Circuit High Voltage (Bank 2 Sensor 1) P0153- O2 Sensor Circuit Slow Response (Bank 2 Sensor 1) P0154- O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1) P0155- O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1) P0156- O2 Sensor Circuit Malfunction (Bank 2 Sensor 2) P0157- O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2) P0158- O2 Sensor Circuit High Voltage (Bank 2 Sensor 2) P0159- O2 Sensor Circuit Slow Response (Bank 2 Sensor 2) P0160- O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2) P0161- O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2) P0162- O2 Sensor Circuit Malfunction (Bank 2 Sensor 3) P0163- O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3) P0164- O2 Sensor Circuit High Voltage (Bank 2 Sensor 3) P0165- O2 Sensor Circuit Slow Response (Bank 2 Sensor 3) P0166- O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3) P0167- O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3) P0170- Fuel Trim Malfunction (Bank 1) P0171- System too Lean (Bank 1) P0172- System too Rich (Bank 1) P0173- Fuel Trim Malfunction (Bank 2) P0174- System too Lean (Bank 2) P0175- System too Rich (Bank 2) P0176- Fuel Composition Sensor Circuit Malfunction P0177- Fuel Composition Sensor Circuit Range/Performance P0178- Fuel Composition Sensor Circuit Low Input P0179- Fuel Composition Sensor Circuit High Input P0180- Fuel Temperature Sensor A Circuit Malfunction P0181- Fuel Temperature Sensor A Circuit Range/Performance P0182- Fuel Temperature Sensor A Circuit Low Input P0183- Fuel Temperature Sensor A Circuit High Input P0184- Fuel Temperature Sensor A Circuit Intermittent P0185- Fuel Temperature Sensor B Circuit Malfunction P0186- Fuel Temperature Sensor B Circuit Range/Performance P0187- Fuel Temperature Sensor B Circuit Low Input P0188- Fuel Temperature Sensor B Circuit High Input P0189- Fuel Temperature Sensor B Circuit Intermittent P0190- Fuel Rail Pressure Sensor Circuit Malfunction P0191- Fuel Rail Pressure Sensor Circuit Range/Performance P0192- Fuel Rail Pressure Sensor Circuit Low Input P0193- Fuel Rail Pressure Sensor Circuit High Input P0194- Fuel Rail Pressure Sensor Circuit Intermittent P0195- Engine Oil Temperature Sensor Malfunction P0196- Engine Oil Temperature Sensor Range/Performance P0197- Engine Oil Temperature Sensor Low P0198- Engine Oil Temperature Sensor High P0199- Engine Oil Temperature Sensor Intermittent P0200- Injector Circuit Malfunction P0201- Injector Circuit Malfunction - Cylinder 1 P0202- Injector Circuit Malfunction - Cylinder 2 P0203- Injector Circuit Malfunction - Cylinder 3 P0204- Injector Circuit Malfunction - Cylinder 4 P0205- Injector Circuit Malfunction - Cylinder 5 P0206- Injector Circuit Malfunction - Cylinder 6 P0207- Injector Circuit Malfunction - Cylinder 7 P0208- Injector Circuit Malfunction - Cylinder 8 P0209- Injector Circuit Malfunction - Cylinder 9 P0210- Injector Circuit Malfunction - Cylinder 10 P0211- Injector Circuit Malfunction - Cylinder 11 P0212- Injector Circuit Malfunction - Cylinder 12 P0213- Cold Start Injector 1 Malfunction P0214- Cold Start Injector 2 Malfunction P0215- Engine Shutoff Solenoid Malfunction P0216- Injection Timing Control Circuit Malfunction P0217- Engine Overtemp Condition P0218- Transmission Over Temperature Condition P0219- Engine Overspeed Condition P0220- Throttle/Petal Position Sensor/Switch B Circuit Malfunction P0221- Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem P0222- Throttle/Petal Position Sensor/Switch B Circuit Low Input P0223- Throttle/Petal Position Sensor/Switch B Circuit High Input P0224- Throttle/Petal Position Sensor/Switch B Circuit Intermittent P0225- Throttle/Petal Position Sensor/Switch C Circuit Malfunction P0226- Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem P0227- Throttle/Petal Position Sensor/Switch C Circuit Low Input P0228- Throttle/Petal Position Sensor/Switch C Circuit High Input P0229- Throttle/Petal Position Sensor/Switch C Circuit Intermittent P0230- Fuel Pump Primary Circuit Malfunction P0231- Fuel Pump Secondary Circuit Low P0232- Fuel Pump Secondary Circuit High P0233- Fuel Pump Secondary Circuit Intermittent P0234- Engine Overboost Condition P0235- Turbocharger Boost Sensor A Circuit Malfunction P0236- Turbocharger Boost Sensor A Circuit Range/Performance P0237- Turbocharger Boost Sensor A Circuit Low P0238- Turbocharger Boost Sensor A Circuit High P0239- Turbocharger Boost Sensor B Malfunction P0240- Turbocharger Boost Sensor B Circuit Range/Performance P0241- Turbocharger Boost Sensor B Circuit Low P0242- Turbocharger Boost Sensor B Circuit High P0243- Turbocharger Wastegate Solenoid A Malfunction P0244- Turbocharger Wastegate Solenoid A Range/Performance P0245- Turbocharger Wastegate Solenoid A Low P0246- Turbocharger Wastegate Solenoid A High P0247- Turbocharger Wastegate Solenoid B Malfunction P0248- Turbocharger Wastegate Solenoid B Range/Performance P0249- Turbocharger Wastegate Solenoid B Low P0250- Turbocharger Wastegate Solenoid B High P0251- Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector) P0252- Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector) P0253- Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector) P0254- Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector) P0255- Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector) P0256- Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector) P0257- Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector) P0258- Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector) P0259- Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector) P0260- Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
Check ya later!
P0261- Cylinder 1 Injector Circuit Low
P0262- Cylinder 1 Injector Circuit High P0263- Cylinder 1 Contribution/Balance Fault P0264- Cylinder 2 Injector Circuit Low P0265- Cylinder 2 Injector Circuit High P0266- Cylinder 2 Contribution/Balance Fault P0267- Cylinder 3 Injector Circuit Low P0268- Cylinder 3 Injector Circuit High P0269- Cylinder 3 Contribution/Balance Fault P0270- Cylinder 4 Injector Circuit Low P0271- Cylinder 4 Injector Circuit High P0272- Cylinder 4 Contribution/Balance Fault P0273- Cylinder 5 Injector Circuit Low P0274- Cylinder 5 Injector Circuit High P0275- Cylinder 5 Contribution/Balance Fault P0276- Cylinder 6 Injector Circuit Low P0277- Cylinder 6 Injector Circuit High P0278- Cylinder 6 Contribution/Balance Fault P0279- Cylinder 7 Injector Circuit Low P0280- Cylinder 7 Injector Circuit High P0281- Cylinder 7 Contribution/Balance Fault P0282- Cylinder 8 Injector Circuit Low P0283- Cylinder 8 Injector Circuit High P0284- Cylinder 8 Contribution/Balance Fault P0285- Cylinder 9 Injector Circuit Low P0286- Cylinder 9 Injector Circuit High P0287- Cylinder 9 Contribution/Balance Fault P0288- Cylinder 10 Injector Circuit Low P0289- Cylinder 10 Injector Circuit High P0290- Cylinder 10 Contribution/Balance Fault P0291- Cylinder 11 Injector Circuit Low P0292- Cylinder 11 Injector Circuit High P0293- Cylinder 11 Contribution/Balance Fault P0294- Cylinder 12 Injector Circuit Low P0295- Cylinder 12 Injector Circuit High P0296- Cylinder 12 Contribution/Range Fault P0300- Random/Multiple Cylinder Misfire Detected P0301- Cylinder 1 Misfire Detected P0302- Cylinder 2 Misfire Detected P0303- Cylinder 3 Misfire Detected P0304- Cylinder 4 Misfire Detected P0305- Cylinder 5 Misfire Detected P0306- Cylinder 6 Misfire Detected P0307- Cylinder 7 Misfire Detected P0308- Cylinder 8 Misfire Detected P0309- Cylinder 9 Misfire Detected P0311- Cylinder 11 Misfire Detected P0312- Cylinder 12 Misfire Detected P0320- Ignition/Distributor Engine Speed Input Circuit Malfunction P0321- Ignition/Distributor Engine Speed Input Circuit Range/Performance P0322- Ignition/Distributor Engine Speed Input Circuit No Signal P0323- Ignition/Distributor Engine Speed Input Circuit Intermittent P0325- Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor) P0326- Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor) P0327- Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor) P0328- Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor) P0329- Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor) P0330- Knock Sensor 2 Circuit Malfunction (Bank 2) P0331- Knock Sensor 2 Circuit Range/Performance (Bank 2) P0332- Knock Sensor 2 Circuit Low Input (Bank 2) P0333- Knock Sensor 2 Circuit High Input (Bank 2) P0334- Knock Sensor 2 Circuit Intermittent (Bank 2) P0335- Crankshaft Position Sensor A Circuit Malfunction P0336- Crankshaft Position Sensor A Circuit Range/Performance P0337- Crankshaft Position Sensor A Circuit Low Input P0338- Crankshaft Position Sensor A Circuit High Input P0339- Crankshaft Position Sensor A Circuit Intermittent P0340- Camshaft Position Sensor Circuit Malfunction P0341- Camshaft Position Sensor Circuit Range/Performance P0342- Camshaft Position Sensor Circuit Low Input P0343- Camshaft Position Sensor Circuit High Input P0344- Camshaft Position Sensor Circuit Intermittent P0350- Ignition Coil Primary/Secondary Circuit Malfunction P0351- Ignition Coil A Primary/Secondary Circuit Malfunction P0352- Ignition Coil B Primary/Secondary Circuit Malfunction P0353- Ignition Coil C Primary/Secondary Circuit Malfunction P0354- Ignition Coil D Primary/Secondary Circuit Malfunction P0355- Ignition Coil E Primary/Secondary Circuit Malfunction P0356- Ignition Coil F Primary/Secondary Circuit Malfunction P0357- Ignition Coil G Primary/Secondary Circuit Malfunction P0358- Ignition Coil H Primary/Secondary Circuit Malfunction P0359- Ignition Coil I Primary/Secondary Circuit Malfunction P0360- Ignition Coil J Primary/Secondary Circuit Malfunction P0361- Ignition Coil K Primary/Secondary Circuit Malfunction P0362- Ignition Coil L Primary/Secondary Circuit Malfunction P0370- Timing Reference High Resolution Signal A Malfunction P0371- Timing Reference High Resolution Signal A Too Many Pulses P0372- Timing Reference High Resolution Signal A Too Few Pulses P0373- Timing Reference High Resolution Signal A Intermittent/Erratic Pulses P0374- Timing Reference High Resolution Signal A No Pulses P0375- Timing Reference High Resolution Signal B Malfunction P0376- Timing Reference High Resolution Signal B Too Many Pulses P0377- Timing Reference High Resolution Signal B Too Few Pulses P0378- Timing Reference High Resolution Signal B Intermittent/Erratic Pulses P0379- Timing Reference High Resolution Signal B No Pulses P0380- Glow Plug/Heater Circuit "A" Malfunction P0381- Glow Plug/Heater Indicator Circuit Malfunction P0382- Glow Plug/Heater Circuit "B" Malfunction P0385- Crankshaft Position Sensor B Circuit Malfunction P0386- Crankshaft Position Sensor B Circuit Range/Performance P0387- Crankshaft Position Sensor B Circuit Low Input P0388- Crankshaft Position Sensor B Circuit High Input P0389- Crankshaft Position Sensor B Circuit Intermittent P0400- Exhaust Gas Recirculation Flow Malfunction P0401- Exhaust Gas Recirculation Flow Insufficient Detected P0402- Exhaust Gas Recirculation Flow Excessive Detected P0403- Exhaust Gas Recirculation Circuit Malfunction P0404- Exhaust Gas Recirculation Circuit Range/Performance P0405- Exhaust Gas Recirculation Sensor A Circuit Low P0406- Exhaust Gas Recirculation Sensor A Circuit High P0407- Exhaust Gas Recirculation Sensor B Circuit Low P0408- Exhaust Gas Recirculation Sensor B Circuit High P0410- Secondary Air Injection System Malfunction P0411- Secondary Air Injection System Incorrect Flow Detected P0412- Secondary Air Injection System Switching Valve A Circuit Malfunction P0413- Secondary Air Injection System Switching Valve A Circuit Open P0414- Secondary Air Injection System Switching Valve A Circuit Shorted P0415- Secondary Air Injection System Switching Valve B Circuit Malfunction P0416- Secondary Air Injection System Switching Valve B Circuit Open P0417- Secondary Air Injection System Switching Valve B Circuit Shorted P0418- Secondary Air Injection System Relay "A" Circuit Malfunction P0419- Secondary Air Injection System Relay "B" Circuit Malfunction P0420- Catalyst System Efficiency Below Threshold (Bank 1) P0421- Warm Up Catalyst Efficiency Below Threshold (Bank 1) P0422- Main Catalyst Efficiency Below Threshold (Bank 1) P0423- Heated Catalyst Efficiency Below Threshold (Bank 1) P0424- Heated Catalyst Temperature Below Threshold (Bank 1) P0430- Catalyst System Efficiency Below Threshold (Bank 2) P0431- Warm Up Catalyst Efficiency Below Threshold (Bank 2) P0432- Main Catalyst Efficiency Below Threshold (Bank 2) P0433- Heated Catalyst Efficiency Below Threshold (Bank 2) P0434- Heated Catalyst Temperature Below Threshold (Bank 2) P0440- Evaporative Emission Control System Malfunction P0441- Evaporative Emission Control System Incorrect Purge Flow P0442- Evaporative Emission Control System Leak Detected (small leak) P0443- Evaporative Emission Control System Purge Control Valve Circuit Malfunction P0444- Evaporative Emission Control System Purge Control Valve Circuit Open P0445- Evaporative Emission Control System Purge Control Valve Circuit Shorted P0446- Evaporative Emission Control System Vent Control Circuit Malfunction P0447- Evaporative Emission Control System Vent Control Circuit Open P0448- Evaporative Emission Control System Vent Control Circuit Shorted P0449- Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction P0450- Evaporative Emission Control System Pressure Sensor Malfunction P0451- Evaporative Emission Control System Pressure Sensor Range/Performance P0452- Evaporative Emission Control System Pressure Sensor Low Input P0453- Evaporative Emission Control System Pressure Sensor High Input P0454- Evaporative Emission Control System Pressure Sensor Intermittent P0455- Evaporative Emission Control System Leak Detected (gross leak) P0460- Fuel Level Sensor Circuit Malfunction P0461- Fuel Level Sensor Circuit Range/Performance P0462- Fuel Level Sensor Circuit Low Input P0463- Fuel Level Sensor Circuit High Input P0464- Fuel Level Sensor Circuit Intermittent P0465- Purge Flow Sensor Circuit Malfunction P0466- Purge Flow Sensor Circuit Range/Performance P0467- Purge Flow Sensor Circuit Low Input P0468- Purge Flow Sensor Circuit High Input P0469- Purge Flow Sensor Circuit Intermittent P0470- Exhaust Pressure Sensor Malfunction P0471- Exhaust Pressure Sensor Range/Performance P0472- Exhaust Pressure Sensor Low P0473- Exhaust Pressure Sensor High P0474- Exhaust Pressure Sensor Intermittent P0475- Exhaust Pressure Control Valve Malfunction P0476- Exhaust Pressure Control Valve Range/Performance P0477- Exhaust Pressure Control Valve Low P0478- Exhaust Pressure Control Valve High P0479- Exhaust Pressure Control Valve Intermittent P0480- Cooling Fan 1 Control Circuit Malfunction P0481- Cooling Fan 2 Control Circuit Malfunction P0482- Cooling Fan 3 Control Circuit Malfunction P0483- Cooling Fan Rationality Check Malfunction P0484- Cooling Fan Circuit Over Current P0485- Cooling Fan Power/Ground Circuit Malfunction P0500- Vehicle Speed Sensor Malfunction P0501- Vehicle Speed Sensor Range/Performance P0502- Vehicle Speed Sensor Low Input P0503- Vehicle Speed Sensor Intermittent/Erratic/High P0505- Idle Control System Malfunction P0506- Idle Control System RPM Lower Than Expected P0507- Idle Control System RPM Higher Than Expected P0510- Closed Throttle Position Switch Malfunction P0520- Engine Oil Pressure Sensor/Switch Circuit Malfunction P0521- Engine Oil Pressure Sensor/Switch Circuit Range/Performance P0522- Engine Oil Pressure Sensor/Switch Circuit Low Voltage P0523- Engine Oil Pressure Sensor/Switch Circuit High Voltage P0530- A/C Refrigerant Pressure Sensor Circuit Malfunction P0531- A/C Refrigerant Pressure Sensor Circuit Range/Performance P0532- A/C Refrigerant Pressure Sensor Circuit Low Input P0533- A/C Refrigerant Pressure Sensor Circuit High Input P0534- Air Conditioner Refrigerant Charge Loss P0550- Power Steering Pressure Sensor Circuit Malfunction P0551- Power Steering Pressure Sensor Circuit Range/Performance P0552- Power Steering Pressure Sensor Circuit Low Input P0553- Power Steering Pressure Sensor Circuit High Input P0554- Power Steering Pressure Sensor Circuit Intermittent P0560- System Voltage Malfunction P0561- System Voltage Unstable P0562- System Voltage Low P0563- System Voltage High P0565- Cruise Control On Signal Malfunction P0566- Cruise Control Off Signal Malfunction P0567- Cruise Control Resume Signal Malfunction P0568- Cruise Control Set Signal Malfunction P0569- Cruise Control Coast Signal Malfunction P0570- Cruise Control Accel Signal Malfunction P0571- Cruise Control/Brake Switch A Circuit Malfunction P0572- Cruise Control/Brake Switch A Circuit Low P0573- Cruise Control/Brake Switch A Circuit High P0574- Cruise Control Related Malfunction P0575- Cruise Control Related Malfunction P0576- Cruise Control Related Malfunction P0577- Cruise Control Related Malfunction P0578- Cruise Control Related Malfunction P0579- Cruise Control Related Malfunction P0580- Cruise Control Related Malfunction P0600- Serial Communication Link Malfunction P0601- Internal Control Module Memory Check Sum Error P0602- Control Module Programming Error P0603- Internal Control Module Keep Alive Memory (KAM) Error P0604- Internal Control Module Random Access Memory (RAM) Error P0605- Internal Control Module Read Only Memory (ROM) Error P0606- PCM Processor Fault P0608- Control Module VSS Output "A" Malfunction P0609- Control Module VSS Output "B" Malfunction P0620- Generator Control Circuit Malfunction P0621- Generator Lamp "L" Control Circuit Malfunction P0622- Generator Field "F" Control Circuit Malfunction P0650- Malfunction Indicator Lamp (MIL) Control Circuit Malfunction P0654- Engine RPM Output Circuit Malfunction P0655- Engine Hot Lamp Output Control Circuit Malfucntion P0656- Fuel Level Output Circuit Malfunction P0700- Transmission Control System Malfunction P0701- Transmission Control System Range/Performance P0702- Transmission Control System Electrical P0703- Torque Converter/Brake Switch B Circuit Malfunction P0704- Clutch Switch Input Circuit Malfunction P0705- Transmission Range Sensor Circuit malfunction (PRNDL Input) P0706- Transmission Range Sensor Circuit Range/Performance P0707- Transmission Range Sensor Circuit Low Input P0708- Transmission Range Sensor Circuit High Input P0709- Transmission Range Sensor Circuit Intermittent P0710- Transmission Fluid Temperature Sensor Circuit Malfunction P0711- Transmission Fluid Temperature Sensor Circuit Range/Performance P0712- Transmission Fluid Temperature Sensor Circuit Low Input P0713- Transmission Fluid Temperature Sensor Circuit High Input P0714- Transmission Fluid Temperature Sensor Circuit Intermittent P0715- Input/Turbine Speed Sensor Circuit Malfunction P0716- Input/Turbine Speed Sensor Circuit Range/Performance P0717- Input/Turbine Speed Sensor Circuit No Signal P0718- Input/Turbine Speed Sensor Circuit Intermittent P0719- Torque Converter/Brake Switch B Circuit Low P0720- Output Speed Sensor Circuit Malfunction P0721- Output Speed Sensor Range/Performance P0722- Output Speed Sensor No Signal P0723- Output Speed Sensor Intermittent P0724- Torque Converter/Brake Switch B Circuit High P0725- Engine Speed input Circuit Malfunction P0726- Engine Speed Input Circuit Range/Performance P0727- Engine Speed Input Circuit No Signal P0728- Engine Speed Input Circuit Intermittent
Check ya later!
P0730- Incorrect Gear Ratio
P0731- Gear 1 Incorrect ratio P0732- Gear 2 Incorrect ratio P0733- Gear 3 Incorrect ratio P0734- Gear 4 Incorrect ratio P0735- Gear 5 Incorrect ratio P0736- Reverse incorrect gear ratio P0740- Torque Converter Clutch Circuit Malfuction P0741- Torque Converter Clutch Circuit Performance or Stuck Off P0742- Torque Converter Clutch Circuit Stuck On P0743- Torque Converter Clutch Circuit Electrical P0744- Torque Converter Clutch Circuit Intermittent P0745- Pressure Control Solenoid Malfunction P0746- Pressure Control Solenoid Performance or Stuck Off P0747- Pressure Control Solenoid Stuck On P0748- Pressure Control Solenoid Electrical P0749- Pressure Control Solenoid Intermittent P0750- Shift Solenoid A Malfunction P0751- Shift Solenoid A Performance or Stuck Off P0752- Shift Solenoid A Stuck On P0753- Shift Solenoid A Electrical P0754- Shift Solenoid A Intermittent P0755- Shift Solenoid B Malfunction P0756- Shift Solenoid B Performance or Stuck Off P0757- Shift Solenoid B Stuck On P0758- Shift Solenoid B Electrical P0759- Shift Solenoid B Intermittent P0760- Shift Solenoid C Malfunction P0761- Shift Solenoid C Performance or Stuck Off P0762- Shift Solenoid C Stuck On P0763- Shift Solenoid C Electrical P0764- Shift Solenoid C Intermittent P0765- Shift Solenoid D Malfunction P0766- Shift Solenoid D Performance or Stuck Off P0767- Shift Solenoid D Stuck On P0768- Shift Solenoid D Electrical P0769- Shift Solenoid D Intermittent P0770- Shift Solenoid E Malfunction P0771- Shift Solenoid E Performance or Stuck Off P0772- Shift Solenoid E Stuck On P0773- Shift Solenoid E Electrical P0774- Shift Solenoid E Intermittent P0780- Shift Malfunction P0781- 1-2 Shift Malfunction P0782- 2-3 Shift Malfunction P0783- 3-4 Shift Malfunction P0784- 4-5 Shift Malfunction P0785- Shift/Timing Solenoid Malfunction P0786- Shift/Timing Solenoid Range/Performance P0787- Shift/Timing Solenoid Low P0788- Shift/Timing Solenoid High P0789- Shift/Timing Solenoid Intermittent P0790- Normal/Performance Switch Circuit Malfunction P0801- Reverse Inhibit Control Circuit Malfunction P0803- 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction P0804- 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction P1106- Manifold Absolute Pressure (MAP) sensor circuit intermittent high voltage P1107- Manifold Absolute Pressure (MAP) sensor circuit intermittent low voltage P1108- BARO to MAP signal circuit comparison too high P1111- Intake Air Temperature (IAT) sensor intermittent high voltage P1112- Intake Air Temperature (IAT) sensor intermittent low voltage P1114- Engine Coolant Temperature (ECT) sensor circuit intermittent low voltage P1115- Engine Coolant Temperature (ECT) sensor circuit intermittent high voltage P1121- Throttle Position (TP) sensor inconsistent with MAF Sensor high voltage P1122- Throttle Position (TP) sensor inconsistent with MAF Sensor low voltage P1133- Heated Oxygen Sensor (HO2S) insufficient switching bank 1 sensor 1 (Rear Bank) P1134- Heated Oxygen Sensor (HO2S) transition time ratio bank 1 sensor 1 (Rear Bank) P1153- Heated Oxygen Sensor (HO2S) insufficient switching bank 2 sensor 1 (Front Bank) P1154- Heated Oxygen Sensor (HO2S) transition time ratio bank 2 sensor 1 (Front Bank) P1189- Engine Oil Pressure Switch Circuit P1258- Engine Metal Over Temperature Protection P1320- Ignition Control (IC) Module 4x Reference Circuit Intermittent No Pulses P1323- Ignition Control (IC) Module 24x Reference Circuit low frequency P1350- Ignition Control System P1370- Ignition Control (IC) Module 4x Reference too many pulses P1371- Ignition Control (IC) Module 4x Reference too few pulses P1375- Ignition Control (IC) Module 24x Reference High Voltage P1376- Ignition Ground Circuit P1377- Ignition Control (IC) Module Cam Pulse to 4x Reference Pulse Comparison P1380- EBTCM DTC Detected-Rough Data Unusable P1381- Misfire Detected-No EBTCM/PCM Serial Data P1404- Exhaust Gas Recirculation (EGR) Valve Pintle Stuck Open P1441- Evaporative System Flow During Non-Purge P1483- Engine Cooling System Performance P1508- Idle Air Control (IAC) System -Low RPM P1520- Intake Manifold Runner Control (IMRC) circuit malfunction P1524- Throttle Position (TP) Sensor Learned Closed Throttle Angle Degrees Out-Of-Range P1527- Trans Range / Pressure Switch Comparison P1554- Cruise Engaged Circuit High Voltage P1560- Cruise Control System-Transaxle Not in Drive P1564- Cruise Control System-Vehicle Acceleration too high P1566- Cruise Control System-Engine RPM Too High P1567- Cruise Control- ABCS Active P1570- Cruise Control System - Traction Control Active P1571- Traction Control System PWM Circuit No Frequency P1574- EBTCM System- Stop Lamp Switch Circuit High Voltage P1575- Extended Travel Brake Switch Circuit High Voltage P1579- Park/Neutral to Drive/Reverse At high Throttle Angle P1599- Engine Stall or Near Stall Detected P1602- Loss of EBTCM Serial Data P1603- Loss of SDM Serial Data P1604- Loss of IPC Serial Data P1605- Loss of HVACC Serial Data P1610- Loss of PZM Serial Data P1611- Loss of CVRTD Serial Data P1617- Engine Oil Level Switch Circuit P1621- PCM Memory Performance P1626- Theft Deterrent System - Fuel Enable Circuit P1630- Theft Deterrent - PCM in Learn Mode P1631- Theft Deterrent - Password Incorrect P1632- Theft Deterrent - Fuel Disabled P1633- Ignition Supplement Power Circuit Low Voltage P1634- Ignition 1 Power Circuit Low Voltage P1640- Driver 1 - Input High Voltage P1641- Malfunction Indicator Lamp (MIL) Control Circuit P1642- Vehicle Speed Output Circuit P1644- Delivered Torque Output Circuit P1645- EVAP Solenoid Output Circuit P1646- EVAP Vent Valve Output Circuit P1650- Driver 2 - Input High Voltage P1652- Lift/Dive Circuit P1654- Cruise Disable Output Circuit P1660- Cooling Fan Control Circuits
