oLD sCHooL fOOL
OBD code...
good and bad news.... I went to a local car show and won a 1st class award for 79 & up mustang class.
and it was my first car show I put the stang in..... the bad.... I prepped/cleaned up my engine for the 2nd time in 3 years! Used engine degreaser, rags, and H20. Was very cautious not to wet the fuse box,alternator,etc... Also tried not to let water run near the spark plug alley when cleaning the valve covers. I had nightmares with my old 97GT. Water would leak into the spark plug holes and foul up the spark plug making the stang drive hidious for about 2 days. I would find coolant in the spark plug holes after yanking out the plugs. I'm thinking this is what happened to my 99 2valve b/c now the engine is idling and driving hidious. It's shooting consistent code P0305 even after clearing it. Someone please post meaning of code and suggestions on how to clear this mess.
March under-drive pulleys, RAM H/D clutch, TriAx, Pro5.0 handle, BBK plenum, 75mm PP t/body, C&L True Flow polished pipe, SVT focus fuel pump, UPR O/R X, 2 chambered Flows, Ford Racing gears 4.10's, Eibach Pro Kit, energy suspension spring isolators, NT555 285/40/18s (rear), 18x9 18x10s chrome Saleens, and a shit load of interior,exterior cosmetic upgrades... ![]()
#2 | |
The "Senior" Member
OBD-II Trouble Code: P0305 Cylinder 5 Five Misfire Detected |
oLD sCHooL fOOL
correct me if I'm wrong - firing order of cylinders on drivers side from front to rear is 5,6,7,8
#4 | |
The "Senior" Member
#5 | |
re re
I am thinking you have a weak coil then.
1,2,3,4 is passenger, 5,6,7,8 is driver.
oLD sCHooL fOOL
thanks jody - around how much should I expect to pay for an individual coil/boot?
oLD sCHooL fOOL
or even a whole set? though I am hesistant to think the dealership doesn't sell individual coils...
You can get coils individually, i have 3 coils that are used and in good condition, that id sell ya. Pm me
oLD sCHooL fOOL
96greengt and Aguilarf were right on the money. Yanked out coil on plug COP
for cylinder 5 yesterday after work. I measured 0.5 ohms resistance between primary terminals (as it should) then measured 8.89K ohm resistance between the secondary terminals (manual shows it should read around 5.5K ohms). So I bought a new COP and installed it ...... cleared code P0305 and stang now runs top notch again! hells yeah ..... thanks
oLD sCHooL fOOL
if i lived in lufkin I would have contacted you - thanks though
