Pleasant Pheasant Plucker
OBD II Codes continued
here's the rest of the generic OBD II Powertrain codes...
P0001 Fuel Volume Regulator Control Circuit / Open P0002 Fuel Volume Regulator Control Circuit Range/Performance P0003 Fuel Volume Regulator Control Circuit Low P0004 Fuel Volume Regulator Control Circuit High P0005 Fuel Shutoff Valve A Control Circuit / Open P0006 Fuel Shutoff Valve A Control Circuit Low P0007 Fuel Shutoff Valve A Control Circuit High P0008 Engine Position System Performance - Bank 1 P0009 Engine Position System Performance - Bank 2 P000A Intake (A) Camshaft Position Slow Response Bank 1 P000B Exhaust (B) Camshaft Position Slow Response Bank 1 P000C Intake (A) Camshaft Position Slow Response Bank 2 P000D Exhaust (B) Camshaft Position Slow Response Bank 2 P0010 Intake (A) Camshaft Position Actuator Circuit / Open (Bank 1) P0011 Intake (A) Camshaft Position Timing - Over-Advanced (Bank 1) P0012 Intake (A) Camshaft Position Timing - Over-Retarded (Bank 1) P0013 Exhaust (B) Camshaft Position Actuator Circuit / Open (Bank 1) P0014 Exhaust (B) Camshaft Position Timing - Over-Advanced (Bank 1) P0015 Exhaust (B) Camshaft Position Timing - Over-Retarded (Bank 1) P0016 Crankshaft Position - Camshaft Position Correlation - Bank 1 Sensor A P0017 Crankshaft Position - Camshaft Position Correlation - Bank 1 Sensor B P0018 Crankshaft Position - Camshaft Position Correlation - Bank 2 Sensor A P0019 Crankshaft Position - Camshaft Position Correlation - Bank 2 Sensor B P0020 Intake (A) Camshaft Position Actuator Circuit / Open (Bank 2) P0021 Intake (A) Camshaft Position Timing - Over-Advanced (Bank 2) P0022 Intake (A) Camshaft Position Timing - Over-Retarded (Bank 2) P0023 Exhaust (B) Camshaft Position Actuator Circuit / Open (Bank 2) P0024 Exhaust (B) Camshaft Position Timing - Over-Advanced (Bank 2) P0025 Exhaust (B) Camshaft Position Timing - Over-Retarded (Bank 2) P0026 Intake Valve Control Solenoid Circuit Range/Performance (Bank 1) P0027 Exhaust Valve Control Solenoid Circuit Range/Performance (Bank 1) P0028 Intake Valve Control Solenoid Circuit Range/Performance (Bank 2) P0029 Exhaust Valve Control Solenoid Circuit Range/Performance (Bank 2) P0030 HO2S Heater Control Circuit (Bank 1, Sensor 1) P0031 HO2S Heater Control Circuit Low (Bank 1, Sensor 1) P0032 HO2S Heater Control Circuit High (Bank 1, Sensor 1) P0033 Turbocharger/Supercharger Bypass Valve Control Circuit / Open P0034 Turbocharger/Supercharger Bypass Valve Control Circuit Low P0035 Turbocharger/Supercharger Bypass Valve Control Circuit High P0036 HO2S Heater Control Circuit (Bank 1, Sensor 2) P0037 HO2S Heater Control Circuit Low (Bank 1, Sensor 2) P0038 HO2S Heater Control Circuit High (Bank 1, Sensor 2) P0039 Turbocharger/Supercharger Bypass Valve Control Circuit Range/Performance P0040 Oxygen Sensor Signals Swapped Bank 1 Sensor 1 / Bank 2 Sensor 1 P0041 Oxygen Sensor Signals Swapped Bank 1 Sensor 2 / Bank 2 Sensor 2 P0042 HO2S Heater Control Circuit (Bank 1, Sensor 3) P0043 HO2S Heater Control Circuit Low (Bank 1, Sensor 3) P0044 HO2S Heater Control Circuit High (Bank 1, Sensor 3) P0045 Turbocharger/Supercharger Boost Control Solenoid A Circuit / Open P0046 Turbocharger/Supercharger Boost Control Solenoid A Circuit Range/Performance P0047 Turbocharger/Supercharger Boost Control Solenoid A Circuit Low P0048 Turbocharger/Supercharger Boost Control Solenoid A Circuit High P0049 Turbocharger/Supercharger Turbine Overspeed P004A Turbocharger/Supercharger Boost Control Solenoid B Circuit / Open P004B Turbocharger/Supercharger Boost Control Solenoid B Circuit Range/Performance P004C Turbocharger/Supercharger Boost Control Solenoid B Circuit Low P004D Turbocharger/Supercharger Boost Control Solenoid B Circuit High P004E Turbocharger/Supercharger Boost Control Solenoid A Circuit Intermittent/Erratic P004F Turbocharger/Supercharger Boost Control Solenoid B Circuit Intermittent/Erratic P0050 HO2S Heater Control Circuit (Bank 2, Sensor 1) P0051 HO2S Heater Control Circuit Low (Bank 2, Sensor 1) P0052 HO2S Heater Control Circuit High (Bank 2, Sensor 1) P0053 HO2S Heater Resistance (Bank 1, Sensor 1) P0054 HO2S Heater Resistance (Bank 1, Sensor 2) P0055 HO2S Heater Resistance (Bank 1, Sensor 3) P0056 HO2S Heater Control Circuit (Bank 2, Sensor 2) P0057 HO2S Heater Control Circuit Low (Bank 2, Sensor 2) P0058 HO2S Heater Control Circuit High (Bank 2, Sensor 2) P0059 HO2S Heater Resistance (Bank 2, Sensor 1) P0060 HO2S Heater Resistance (Bank 2, Sensor 2) P0061 HO2S Heater Resistance (Bank 2, Sensor 3) P0062 HO2S Heater Control Circuit (Bank 2, Sensor 3) P0063 HO2S Heater Control Circuit Low (Bank 2, Sensor 3) P0064 HO2S Heater Control Circuit High (Bank 2, Sensor 3) P0065 Air Assisted Injector Control Range/Performance P0066 Air Assisted Injector Control Circuit or Circuit Low P0067 Air Assisted Injector Control Circuit High P0068 MAP / MAF - Throttle Position Correlation P0069 MAP - Barometric Pressure Correlation P006A MAP - Mass or Volume Air Flow Correlation P0070 Ambient Air Temperature Sensor Circuit P0071 Ambient Air Temperature Sensor Range/Performance P0072 Ambient Air Temperature Sensor Circuit Low Input P0073 Ambient Air Temperature Sensor Circuit High Input P0074 Ambient Air Temperature Sensor Circuit Intermittent/Erratic P0075 Intake Valve Control Circuit (Bank 1) P0076 Intake Valve Control Circuit Low (Bank 1) P0077 Intake Valve Control Circuit High (Bank 1) P0078 Exhaust Valve Control Circuit (Bank 1) P0079 Exhaust Valve Control Circuit Low (Bank 1) P0080 Exhaust Valve Control Circuit High (Bank 1) P0081 Intake Valve Control Circuit (Bank 2) P0082 Intake Valve Control Circuit Low (Bank 2) P0083 Intake Valve Control Circuit High (Bank 2) P0084 Exhaust Valve Control Circuit (Bank 2) P0085 Exhaust Valve Control Circuit Low (Bank 2) P0086 Exhaust Valve Control Circuit High (Bank 2) P0087 Fuel Rail/System Pressure - Too Low P0088 Fuel Rail/System Pressure - Too High P0089 Fuel Pressure Regulator Performance P0090 Fuel Pressure Regulator Control Circuit P0091 Fuel Pressure Regulator Control Circuit Low P0092 Fuel Pressure Regulator Control Circuit High P0093 Fuel System Leak Detected - Large Leak P0094 Fuel System Leak Detected - Small Leak P0095 Intake Air Temperature Sensor 2 Circuit P0096 Intake Air Temperature Sensor 2 Circuit Range/Performance P0097 Intake Air Temperature Sensor 2 Circuit Low Input P0098 Intake Air Temperature Sensor 2 Circuit High Input P0099 Intake Air Temperature Sensor 2 Circuit Intermittent/Erratic |
