Old 03-15-2008, 12:47 AM   #1
oLD sCHooL fOOL
seco's Avatar
offset steering rack bushings
Don't know much about them - are they really necessary on lowered stangs? A friend was telling me they some how correct the bump steer??!! IDK - I have Eibach Pro Kit springs installed on my 99 and I don't have these installed. Are they designed to prevent premature tire wear or something? I don't have any premature wear on my front wheels - LMK
March under-drive pulleys, RAM H/D clutch, TriAx, Pro5.0 handle, BBK plenum, 75mm PP t/body, C&L True Flow polished pipe, SVT focus fuel pump, UPR O/R X, 2 chambered Flows, Ford Racing gears 4.10's, Eibach Pro Kit, energy suspension spring isolators, NT555 285/40/18s (rear), 18x9 18x10s chrome Saleens, and a shit load of interior,exterior cosmetic upgrades...
Old 03-15-2008, 08:09 AM   #2
SN-95 Enthusiast
tpcobra95's Avatar
Trader Rating: (4)
I have always been told if you go 1.25 inches or lower you should use them.
95 COBRA= Project Dark Venom
98 GT= DD
tpcobra95 is offline   Reply With Quote
Old 03-15-2008, 09:05 AM   #3
re re
Trader Rating: (14)
I have them on mine, they help out, but they do no 100% correct it. The true way to go is the actual bumpsteer kit.
Originally Posted by ezblonde
Old 03-15-2008, 11:24 AM   #4
Evil Angel
Bigdrumma22's Avatar
Wink
I got them installed on mine and I have Eibach sportlines which have just a lil' more drop then your pro kit. I'm still considering doing the bumpsteer kit like 96greengt mentioned though. I think the bushings help most with rack wear because it helps fix change in stock angles of the tie rods or w/e they call them on the rack. I got them installed with brand new tires, and they don't help with tire wear... a proper alignment does!
2002 Mustang GT, 271hp/306tq on 87 CMR Tune, Roush short throw rally style shifter, King Cobra Clutch, Roush CAI, C&L Plenum, BBK/Roush 75mm T/B, Kooks L/Ts w/catted X, Flowmaster American Thunder Cat-back, Eibach Pro-kit Springs, Energy Suspension bushings, KYB AGX's, Hotchkis C/C plates, UPR ProStreet rear control arms, Brembo Drilled/Hawk pads, BFG's, Dual Halo Projector 8k HIDs, Kenwood: KDC-X790, KAC-9102D, KAC-8402; Infinity: 6810CS, 6812CF; Orion: P series subs all powered by Optima
Bigdrumma22 is online now   Reply With Quote
Old 03-22-2008, 10:53 AM   #5
blackicecobra's Avatar
SAME SITUATION
Not to steal your thunder but this question may help too. I have the same springs and am going to get some offset bushings. DOES ANYONE have any opinions (preferably from experience) about whether to use aluminum or urethane bushings on a stock k-member (02 GT). Which brand is good?
Thanks.
So, you think you're having a bad day? You woke up this morning..........didn't you?
blackicecobra is offline   Reply With Quote
Old 03-22-2008, 11:01 AM   #6
Evil Angel
Wink
Thanks.
I've got energy suspension offset bushings on my 02 GT that I bought from jegs. They were $20 at most, don't remember exactly. If it's a daily driver, I'd go with those.
Old 03-22-2008, 12:44 PM   #7
Jus Workin Away !!!
txlen's Avatar
i used aluminum ones on my last setup and had no probs at all...
Old 03-22-2008, 04:52 PM   #8
God's gift to Dell
SCobraVT99's Avatar
$20 bux for the offset stuff? Isnt a bumpersteer kit only like $150?
Is there any reason to have both, or would the bumpersteer kit do it all?
SCobraVT99 is offline   Reply With Quote
Old 03-22-2008, 08:16 PM   #9
re re
Trader Rating: (14)
The bumpsteer kit is the way to go hands down, you won't have to worry then for the rack bushings. The rubber bushings (urethane) are more prone to a little give/flex, the aluminum have NO flex at all, very responsive.
With a lowered car, the bumpsteer kit, lower ball joints will give it with the correct geometry and awesome steering response.
Old 04-01-2008, 11:05 AM   #10
UT Sucks
All I can say is read:
MM offset aluminum rack bashings - Corner-Carvers Forums
Darren
Old 04-01-2008, 05:27 PM   #11
I put some in and they do help IMO
OK, so I ordered some steeda aluminum offsets and put them in. It was a PITA but worth it. Although not 100%, I do feel a difference....now I don't have to fight the wheel to keep it on the road. Still may do bumpsteer later but I think it was worth it.
