oLD sCHooL fOOL
offset steering rack bushings
Don't know much about them - are they really necessary on lowered stangs? A friend was telling me they some how correct the bump steer??!! IDK - I have Eibach Pro Kit springs installed on my 99 and I don't have these installed. Are they designed to prevent premature tire wear or something? I don't have any premature wear on my front wheels - LMK
March under-drive pulleys, RAM H/D clutch, TriAx, Pro5.0 handle, BBK plenum, 75mm PP t/body, C&L True Flow polished pipe, SVT focus fuel pump, MAC O/R H, 2 chambered Flows, Ford Racing gears 4.10's, Eibach Pro Kit, energy suspension spring isolators, NT555 285/40/18s (rear), 18x9 18x10s chrome Saleens, and a shit load of interior,exterior cosmetic upgrades... ![]()
SN-95 Enthusiast
I have always been told if you go 1.25 inches or lower you should use them.
95 COBRA= Project Dark Venom Drag Project 98 GT= Project Bravo Delta Daily Driver-getting some mods 15.75 @ 87 m.p.h. for now |
#3 | ||
I eated it..
I have them on mine, they help out, but they do no 100% correct it. The true way to go is the actual bumpsteer kit.
Evil Angel
I got them installed on mine and I have Eibach sportlines which have just a lil' more drop then your pro kit. I'm still considering doing the bumpsteer kit like 96greengt mentioned though. I think the bushings help most with rack wear because it helps fix change in stock angles of the tie rods or w/e they call them on the rack. I got them installed with brand new tires, and they don't help with tire wear... a proper alignment does!
SAME SITUATION
Not to steal your thunder but this question may help too. I have the same springs and am going to get some offset bushings. DOES ANYONE have any opinions (preferably from experience) about whether to use aluminum or urethane bushings on a stock k-member (02 GT). Which brand is good?
Thanks. ![]()
Evil Angel
#9 | ||
I eated it..
The bumpsteer kit is the way to go hands down, you won't have to worry then for the rack bushings. The rubber bushings (urethane) are more prone to a little give/flex, the aluminum have NO flex at all, very responsive.
With a lowered car, the bumpsteer kit, lower ball joints will give it with the correct geometry and awesome steering response.
UT Sucks
I put some in and they do help IMO
OK, so I ordered some steeda aluminum offsets and put them in. It was a PITA but worth it. Although not 100%, I do feel a difference....now I don't have to fight the wheel to keep it on the road. Still may do bumpsteer later but I think it was worth it.
