Old 02-21-2008, 06:15 PM   #1
I can annoy you and Your Momma
jstang6969's Avatar
Oil Cooler
Its not a secret that I dont know a thing about my motor. I just had got it back from a dealer up here after having the coolant system pressure tested. The guy said it was from an area up around the oil cooler. He said the area was too tight to be able to see it. (of course it wasnt a Ford Dealership) Can someone elaborate on this, or show a pic or something.
98 cobra btw
~teh thing is Im just so smart, im starting over
Originally Posted by X2CRAYZIX View Post
Last time I checked I was a WHITE BOY
jstang6969 is offline   Reply With Quote
Old 02-21-2008, 06:43 PM   #2
LOL @ your mom
Trader Rating: (22)
Cooler looks like below. Normally, they just leak oil (known for that too) and is a stupid design by Ford anyway. I don't have one on mine for that reason. It can be bypassed, it's just a PITA to get too.
Old 02-21-2008, 09:41 PM   #3
jstang6969's Avatar
Thanks for the pic. Is it safe to say that if I replace it that my leak would stop, or is there other factors involved?
Old 02-21-2008, 10:41 PM   #4
LOL @ your mom
Trader Rating: (22)
Dunno, with out looking at it, hard to say. I'd say remove it completely. Where the oil filter mounts, that is the cooler.
Old 02-21-2008, 10:50 PM   #5
jstang6969's Avatar
word. thanks. I will try to do it this week. Its a slow leak, so its not urgent.
Old 02-21-2008, 10:51 PM   #6
LOL @ your mom
Trader Rating: (22)
You can always add a stop leak, but I don't condone that, but I have used it with good results.
Old 02-21-2008, 11:02 PM   #7
speed-olic
machgsxr's Avatar
Trader Rating: (9)
I have an oil cooler, but it look's a little different than that one. Same function though just different design.
It's on the driver's side of the block if that help's to tell you where to look to see.
Old 02-21-2008, 11:02 PM   #8
jstang6969's Avatar
What kind? I dont use that stuff so I dont know which is good. Put it in the crossover tube?
Old 02-21-2008, 11:05 PM   #9
LOL @ your mom
Trader Rating: (22)
No, you can put it in the reservoir straight. Bars leak is good, but it is real clumpy. If you can find "liquid glass" (and not the polish) that works wonders.
Old 02-21-2008, 11:07 PM   #10
jstang6969's Avatar
^lol. Thanks you guys for the help.
Old 02-25-2008, 11:21 AM   #11
jstang6969's Avatar
I put some bars stop leak in it and it hasnt leaked so far. Which usually I would have seen it by now. Just a band aid for now, but it works. Thanks guys
